Home > Expedition & Overland > Winching
555hp
England 2010 Defender 130 Puma 2.4 HCPU Zambezi Silver
Winching
After a Warn winch for my 130 any suggestions
Post #771789 6th May 2019 8:01pm
htb2
Wales
husky if you can get hold of one
Post #771790 6th May 2019 8:05pm
555hp
Are they better than Warn?
Post #771794 6th May 2019 8:12pm
htb2
Wales
Depends what your aiming to do. Ive a warn 8274 on my 110, which I like. The Huskyf rom defunct Superwinch co being worm drive does not need a brake, is slower but reliable, can be had electric, hydraulic or shaft
Post #771811 6th May 2019 9:11pm
555hp
Ok thanks
Post #771818 6th May 2019 9:44pm
benniferj
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
In honesty if you're just wanting a winch for occasional recovery, and a bit more confidence if out somewhere on your own, pretty much any cheap modern winch is going to do the trick.
If you have a more specific requirement, let us know? And something appropriate can be suggested. There is no need to blow loads of money on a winch if you're barely going to use it.
My 90 has a Warn 8274 on the front which is totally fantastic. The rear of that vehicle has a Goodwinch TDS 9.5 on a Dixon tray. My 110 has a brand new Terrafirma winch on the front which I got as a 'cheapy' for the odd self recovery, ancillary use. It did the trick and got me out of a hole on Sunday. Not with the same ferocity as the 8274 I'm used to. But absolutely fine. And a third of the price!
Post #772225 9th May 2019 7:53am
