![]() | Home > Expedition & Overland > Winching |
555hp Member Since: 02 Mar 2019 Location: Herefordshire Posts: 17 ![]() ![]() ![]() |
After a Warn winch for my 130 any suggestions
Cheers |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548 ![]() ![]() |
husky if you can get hold of one
Are they better than Warn?
Ok thanks
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 ![]() ![]() ![]() |
In honesty if you're just wanting a winch for occasional recovery, and a bit more confidence if out somewhere on your own, pretty much any cheap modern winch is going to do the trick.
If you have a more specific requirement, let us know? And something appropriate can be suggested. There is no need to blow loads of money on a winch if you're barely going to use it. My 90 has a Warn 8274 on the front which is totally fantastic. The rear of that vehicle has a Goodwinch TDS 9.5 on a Dixon tray. My 110 has a brand new Terrafirma winch on the front which I got as a 'cheapy' for the odd self recovery, ancillary use. It did the trick and got me out of a hole on Sunday. Not with the same ferocity as the 8274 I'm used to. But absolutely fine. And a third of the price! |
