Home > Maintenance & Modifications > Retrofitting high level brake light
dioliahary
Has anyone fitted one to a pre 2002 Defender? 1990 200tdi conversion 90
Post #771101 1st May 2019 8:43pm
donmacn
I'm planning to. I've bought the light - a red LED job - and I was just going to splice the wiring into the existing brake light circuit in the driver's side wiring cover.
To fit the light itself, I'm going to fit a security grill, so I was just going to fix it to that somewhow, either by making up small brackets to bolt on, or just using adhesive foam tape and tie wraps. The light unit is very lightweight so wouldn't cause any problems that way.
Don't know if that helps...? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #771159 2nd May 2019 8:12am
dioliahary
That’s great, wiring I am ok with, securing the light to the glass was my challenge, decided to attach with window adhesive. 1990 200tdi conversion 90
Post #771165 2nd May 2019 8:56am
Balvaig
Geocel do a "mirror fix" silicone sealant. Intended for bathroom mirrors, but should work ok on your light.
Works well as intended on bathroom mirrors, but mine was white.
You would need black or transparent though as it would be visible from outside.
Post #771173 2nd May 2019 10:11am
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I have (but not wired up yet). Used rear view mirror adhesive to fix two studs to the window so that lamp and enclosure could be bolted up. The first time didn't adhere well and pulled off one stud as it was tightened.
Post #771174 2nd May 2019 10:15am
gilarion
Use these as above https://www.ebay.co.uk/itm/Land-Rover-Defe...Sws19Zh2n7
But either use gorilla glue or two-part epoxy glue to fit. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #771203 2nd May 2019 12:50pm
My rear window doesn't/didn't have a brake light.
I got hold of the proper LR light (huge great thing!) and the two threaded bits as above.
Used the "rear view mirror" fitting kit from my local autofactors (you get a little piece of mesh which you cut to size, then cover with the glue stuff and hold it on to the glass)
This:
Seems to hold ok for a while, then one of them falls off. I've tried it several times, then switched to tiger seal panel adhesive, that didn't work, then got my die grinder and "roughed up" the glass where the adhesive would be, and they still fell off eventually.
so now the 3rd brake light is in the garage... must advertise it on here sometime! eventually I'll find a slimline LED light to fit up there.
Don't know how they glue those threaded pieces on at the factory; must be a helluva adhesive.
Post #771231 2nd May 2019 3:45pm
gilarion
Just a guess but probably a correct one that they use a UV curing adhesive as in Permabond. UV adhesives are not really for the home user but kits including a small UV light source are available commercially.
One tip though, make sure both the metal stud and glass are spotlessly clean the tiniest bit of grease even from a finger mark will cause the joint to fail. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #771233 2nd May 2019 3:56pm
dioliahary
Hi Gilarion, how is Wales? My Alloys are still looking good
Post #771236 2nd May 2019 4:23pm
gilarion
Wales is good though because as yet I have not put the Manchester house on the market I am still commuting between the cottage and the house. However, because I have now retired since we last met I aim to make a concerted effort to sell the house this year as I have no real use for it now I am no longer working at MMU.
Glad the alloys are still looking good Smile For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #771239 2nd May 2019 4:42pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
If you're not too fussed about fitting an original part, with a little imagination and access to some scrappers, the possibilities are endless. I fitted a brake light from a Hyundai something, (I think,) with part of the cowl trimmed off, a bit of a homemade bracket and some edge trim where it meets the glass, then just linked in to the normal brake light circuit. Then to finish it off, a bit of suitably shaped trim to cover the bracket.
Post #771241 2nd May 2019 4:45pm
dioliahary
Great job there 1990 200tdi conversion 90
Post #771258 2nd May 2019 7:11pm
hank
Coincidentally this was posted on LR Workshop's page an hour ago
 > 110 XS Double Cab
Post #771388 3rd May 2019 7:30pm
