Home > Tdi > Driver's footwell rust |
https://yrmit.co.uk/product/rhs-footwell-r...-defender/
cut out rusty metal work and use repair panel or steel metal and mig weld in new metal prim & finish paint or go too good local land rover specialist get a quote for the work Last edited by dorsetsmith on 30th Apr 2019 5:45pm. Edited 1 time in total |
30th Apr 2019 4:57pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19568 |
^^^^ This as mentioned.
Don't forget corrosion prevention treatment for any seams and the underside also. For a small part like that you could finish the paint match with an aerosol metallic to match too. Plenty on eBay, if you can find the colour code etc. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
30th Apr 2019 5:40pm |
AndrewFoxPitt Member Since: 30 Apr 2019 Location: London Posts: 5 |
Thanks for the advice, so disconnect the pedals and use an angle grinder to cut it out?
30th Apr 2019 6:16pm |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 745 |
Use a cutting disc or suitable fret saw. Be aware what’s on the other side and watch out for sparks igniting anything. Take special note of fuel lines etc.
30th Apr 2019 7:20pm |
