Home > My Defender > My 1984 Ninety
Page 7 of 12 <123 ... 678 ... 101112>
Procta
ok pal, would have made a nice little upgrade. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #770701 29th Apr 2019 4:41pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Steady progress tonight;
Unseized and stripped the low range mechanism, cleaned it all up, new o-rings lots of fresh grease ready for bolting back on. Appears to be original as uncovered an '84 in the casting. Cool
Started the loose fit of the freshly/badly painted new battery box panels. Bit of a sod getting it all together due to seatbox still being in, but it's there now ready for drilling and riveting Very Happy
 Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #770984 30th Apr 2019 9:59pm
Procta
i think my dads needs to do this on his, the low ratio leaver I seized to hell. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #771004 1st May 2019 6:05am
Byamin
New Zealand 1984 Defender 110 V8 Petrol HCPU Masai Red
Nice job on the battery box repair, looks very tidy! Lucy saved from A parts shelf, 1984 110 V8
Instagram: @ben_j_soffe
Post #771007 1st May 2019 7:13am
L90Andy
Battery box all fixed and seam sealed. Before and after Very Happy
 Instagram: L90andy
Post #771890 7th May 2019 1:01pm
What a great job. Well done for persevering with doing it in-situ. Darren
Post #771930 7th May 2019 4:17pm
L90Andy
Thanks! Yeah its pretty satisfying to not know how the job is going to work out but diving in and getting a good result anyway. Definitely helps I can take my time as its not a daily driver.
Got the refurbished hi/lo mech back on too. The keen eyed amongst you will see I reversed the direction of the linkage pin which was deliberate, thinking "who cares if its a b*tch to get the split pin out I won't have to worry about that for years!" then realising that I forgot to put the nylon bushes back in the linkage Big Cry
And yes, it was a b*tch, but its all done and back in properly now.
Another one ticked off Very Happy
Next installment - diff lock shenanigans. Instagram: L90andy
Post #772122 8th May 2019 3:48pm
Procta
good repair on the battery box, we have to do something with my dads transfer box linkage as its seized to hell. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #772137 8th May 2019 5:20pm
L110CDL
Good jobs done there Thumbs Up Clayton.
Keeper.
Post #772374 9th May 2019 9:11pm
L90Andy
Thanks Very Happy
Onto the INOP diff lock then. Tunnel already being out meant I had decent access to the mechanism, however it was totally obscured with muck.
Searching the web didn't come up with any info on how or what to take apart, so perk of the job - checked the CAD Cool
Looked pretty simple, so got stuck in. Drivers floor panel had to come up a bit to get tool access but got there in the end. Shame reality isn't as clean as virtual!
The good news was the mechanism wasn't seized, so it was just cleaned up. The issue appears to be that the movement isn't transferred from the knob to the mech as the amount of slack at each pivot means the mech doesn't fully actuate.
I replaced the nylon bushes and managed to pack the joints with extra washers to remove the slack. Disappointingly on re-assembly it still doesn't fully work.
The main culprit is the centre pivot. Latest thinking is to drill out the hole and fit a larger roll pin, and make some more spacers.
Only the earliest 13D spec LT77's had this cast arm, later versions changed to the bent metal arm. Perhaps cost and reliability were drivers for that. That makes them rare, and a new one would be £245 Shocked
So it's all back in for now and that's where I'm upto tonight Neutral Instagram: L90andy
Post #773312 15th May 2019 11:38pm
L110CDL
Good that you got stuck in and found out the problem and hopefully get it fixed and working right when time allows Thumbs Up Clayton.
Keeper.
Post #773436 16th May 2019 9:16pm
Procta
where did you get the stuff to sort the linkages out? my dad really needs his sorting out, if you can supply the links I can get the bits and my dad can sort his out. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #773778 18th May 2019 10:42pm
L90Andy
Hi Procta,
It's a busy area of the car with separate linkages for hi/lo and diff lock. Both had issues on mine.
Start with removing the centre access cover under the middle seat (or cubby box) and the tunnel where the levers are (they can stay attached). Then you'll be able to see all the linkages properly.
My hi/lo was seized at the transfer box end so removed the 6 bolt housing as mentioned previously. The shaft was stuck in the housing so loosened it off and replaced the o-rings (part no.FRC5575). I needed 2, but think later boxes only used 1. Fresh grease and all back together, no new linkage bits required Thumbs Up
Different story for the diff lock though, still ongoing with that Rolling Eyes
Hope that helps. Instagram: L90andy
Post #773823 19th May 2019 9:47am
L90Andy
What I thought was going to be a relatively simple resurrection of the diff lock was misguided. Anyone got a towel so I can throw it in!?
I've now replaced all bushes, packed out the pivot slack with additional washers and tonight replaced the diff lock switch.
No change Big Cry
Going to have to get inventive now and get some bits machined to remake the pivot bracket.
Or convert to a later type of mech but I don't have the pivot boss on the side of the gearbox so more head scratching required.
In an effort to at least make positive progress here is a little thing I've 3D printed to hold the interior light now I've converted to soft top. It sandwiches between the mirror mount and holds the light at the same angle as the sunvisors.
Here it is in place to test the positioning;
And here it is with the light fitted. I'll whip it off the next time I've got the paint out and get some satin black on it Cool
I'll put the interior all back together for now as there is nothing else I can do on the diff lock for a while and it only takes a few minutes to get the access panel and tunnel out again. Instagram: L90andy
Post #774110 20th May 2019 9:36pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Liking the light mount Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #774116 20th May 2019 9:46pm
