Home > In Car Electronics > Nakatanenga DAB antenna
Page 3 of 8 <12345678>
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I also cleaned up the under side of the wing and roughed the big silver spacer to try and ensure a good earth but no avail
It does pick up several dab stations using manual tuning but still shows the antenna error on screen 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #769603 22nd Apr 2019 3:48pm
Did you try the aerial connection direct to the DAB box on its own with the Naka booster completely and absolutely disconnected? (Not in-line.)
If so with a non powered aerial I cannot see why that should show any error if the Pinoeer system is self powered.o
I suppose you could also try powering the Nak booster for the aerial via the blue white wire as the manual suggests.
If so that is how the manual suggests an aerial is connected.
Is it on the latest firmware version?
Are you absolutely sure the DAB fittings match up? Some SMA / SMB fixings have a central pin and others not.
Of course naturally mind you Pinoeer will suggest their xxxxxx model number DAB aerial will be the solution.
I wonder if anyone on here has the same set up?
If all check out then the manufacturer may have more info on it. Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #769611 22nd Apr 2019 4:41pm
pj2106
You can’t remove the booster as this is what splits the signal on the naka ariel
I have powered on a separate ign live so shouldn’t be an issue
It’s a brand new model radio only came out 2 weeks ago so I assume it’s the latest software
Going to buy a cheap dab windscreen ariel from halfruads tomorrow and try that at least I’ll know if it’s ariel or hu 2008 110 2.4 XS Utility (Hagrid)
Post #769616 22nd Apr 2019 5:55pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
My first naka antenna had a break in the cable so would not work
Tested to see if a current passed from one end to the other and it did not
Brendan replaced it and the new one works fine
Might be worth a check if not already done
Post #769619 22nd Apr 2019 6:26pm
Have you tried this:
https://www.caravantalk.co.uk/community/to...nna-error/
This function I mentioned before, see if you can find it and turn it 'OFF'.
Apparently a lot of the Pinoneer units can power their own branded aerial.
If the aerial is externally powered the setting should be 'OFF'.
It may be 'on' as standard out of the box, probably in the hope you buy a Pioneer DAB Aerial instead!
Failing that it might be internal, thus contacting Pinoneer for a swap is the answer. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #769640 22nd Apr 2019 8:29pm
pj2106
It does say on in the settings but I can’t alter it??
Going to call the supplier in the morning
Will also try running a current through although I would have thought it wouldn’t pick anything up if was broken??? 2008 110 2.4 XS Utility (Hagrid)
Post #769651 22nd Apr 2019 8:57pm
Probably needs looking at then if that is the case, as it certainly should allow you to switch it on or off according to manuals.
What a pain..
Hope you can get it sorted out, I was after one of these at some point too but at the cost people paid to have these issues isn't inspiring.
If you get a like for like replacement, definitely when fitting make sure the DAB box is fitted first before powering up and that, that setting is turned off before connecting the Nak aerial.
Good luck. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #769674 22nd Apr 2019 11:55pm
pj2106
Got the Dab sorted today😊
Spoke to the supplier of hu they told me how to turn off the hu power for ariel which was a console out job and a bit of a faf
And what do you know all spot on now picks up all stations even where I am in the middle of knowwhere
Happy bunny at last 2008 110 2.4 XS Utility (Hagrid)
Post #770545 28th Apr 2019 5:40pm
Excellent news. 👍🏻 One to remember for anyone else too with similar units.
I have ever had the chance to use DAB on mine yet, but I did try the FM quickly and could definitely tell a difference in that alone first try. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #770549 28th Apr 2019 6:23pm
Sulisuli
Glad you got it sorted Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #770577 28th Apr 2019 8:44pm
JBOSLO
United Kingdom 2004 Defender 90 2.5 TD CSW Oslo Blue
Can anyone give me more detail on what the fix was for the hu ? Having the same problem ...
“Got the Dab sorted today😊
Spoke to the supplier of hu they told me how to turn off the hu power for ariel which was a console out job and a bit of a faf”
Post #778187 19th Jun 2019 9:39pm
Why did you need to get the HU out to do that? If you could kindly share, it may help others. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #778196 19th Jun 2019 10:14pm
JBLancs
England 2011 Defender 110 Puma 2.4 USW Zermatt Silver
I've just fitted my Nakatanenga aerial and it is currently working on FM with my old head unit. Does anyone have any tips of where to piggy back off of for the power to the Naka booster box? I can then fit my new DAB head unit.
Post #824719 12th Apr 2020 8:36am
pj2106
JB
I would take ignition feed from back of barrel and I put the box behind centre dash near radio 2008 110 2.4 XS Utility (Hagrid)
Post #824733 12th Apr 2020 9:31am
JBLancs
Thank you for your reply, is there anywhere I can get this (ie switched live) off the ISO plug rather than trying to get to the awkward ignition barrel switch? Rather than cutting the loom I wondered about getting a male to female ISO loom and cutting that? Just wondered what others had done.
Post #824763 12th Apr 2020 11:43am
