Home > Puma (Tdci) > Milky oil rear axle |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
The next time I'll let someone else do the service. They never examine everything I do
But to add to the below list, I found the oil in the rear axle to be very milky (my guess is a or both seals are leaky). See photo below. I assume I have to replace seals on both sides of the axle. Drain the diff and replace the oil. Do I need to flush the diff and yes, how? And is this an urgent repair? Thnx again (in advance) for your advise. Click image to enlarge It's starting to get a very very long list 1. Coolant loss, luckily it drips so hopefully no head gasket. But Haven't found the leak 2. Aircon isn't working, haven't found leak 3. transfer box is leaking heavily 4. Stubs between exhaust manifold and turbo are still coming loose 5. Wobble at 50-60 mph, suspect steering damper, perhaps trying balancing beads 6. Seals shot at intake manifold (i guess) 7. And last but not least clutch is almost shot. Still have to decide between clutchfix and lof extreme clutch 8. Leaking injector seal a defender from 1984 pretending to be a puma with a touch of Range Rover |
26th Apr 2019 8:15pm |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1829 |
Hi there,
This may or may not be relevant, as I don't know what axle breather/vent you might have fitted, but before you look at anything too technical, do make sure the water isn't getting in that way. Check out this thread I started a little while ago https://www.defender2.net/forum/topic66305.html - (sorry, don't know how to make it a link on the ipad) You can see the state of the 'oil' I took out of my rear axle. The consensus was that it's coming in via the breather, so I've opted for the Gwyn Lewis breather kit to make sure that I don't get water in that way. To be fitted in the next little while. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
26th Apr 2019 8:47pm |
Thnx Guys! Some more things to look at
I’ll look at both your solutions. But i don’t need to flush the diff? I thought draining Will not remove all the oil?? But seriously thanx again for your advise. Just a pity a need so much lately. a defender from 1984 pretending to be a puma with a touch of Range Rover |
26th Apr 2019 9:05pm |
I'd flush the diff if my oil looked like that. Flushing is no more complicated than refilling with oil, taking it for a drive and then draining and refilling, though. Darren
26th Apr 2019 9:31pm |
Using the same oil as regular? Or can i use a cheaper product for the flush? a defender from 1984 pretending to be a puma with a touch of Range Rover
26th Apr 2019 9:33pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19650 |
Moisture would still migrate up around the half shafts too.
If you did do what LRA mentioned you'd be best off leaving it for a while then change it over. And yes, it'd need to be the same oil. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
26th Apr 2019 9:42pm |
Yes, using the same oil. A cheaper alternative would do the job but as it's almost impossible to completely drain an axle, the remainder would just dilute the new oil added later. To be honest, the cost of decent gear oil isn't excessive anyway. Darren
26th Apr 2019 10:06pm |
To get back on your 2 posts. Just checked the rear diff pinion seal. Is too dirty to say for sure but the dirt is pretty greasy. So I think that's a culprit. I cleaned the diff and will look at it in a few days.
Click image to enlarge The breather look pretty okay. I will change it somewhere in the future but when I change the seal I'll put some sealant over it. Click image to enlarge a defender from 1984 pretending to be a puma with a touch of Range Rover |
27th Apr 2019 12:21pm |
