Home > Puma (Tdci) > Milky oil rear axle
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Milky oil rear axle
The next time I'll let someone else do the service. They never examine everything I do Rolling Eyes
But to add to the below list, I found the oil in the rear axle to be very milky (my guess is a or both seals are leaky). See photo below. I assume I have to replace seals on both sides of the axle. Drain the diff and replace the oil.
Do I need to flush the diff and yes, how?
And is this an urgent repair?
Thnx again (in advance) for your advise.
It's starting to get a very very long list Evil or Very Mad
1. Coolant loss, luckily it drips so hopefully no head gasket. But Haven't found the leak
2. Aircon isn't working, haven't found leak
3. transfer box is leaking heavily
4. Stubs between exhaust manifold and turbo are still coming loose
5. Wobble at 50-60 mph, suspect steering damper, perhaps trying balancing beads
6. Seals shot at intake manifold (i guess)
7. And last but not least clutch is almost shot. Still have to decide between clutchfix and lof extreme clutch
8. Leaking injector seal a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #770274 26th Apr 2019 8:15pm
That’ll be water in the oil. Good job you caught it.
The diff pinion oil seal being shot is the common culprit for ingress.
I have had this seal play mine up multiple times, the reason has been unknown and even the pinion its self was changed to and it still did it.
For now, it’s okay.
Ingress via the hubs is not so likely unless you wade deep or depending on if you have sealed DM’s or not.
All you can do really is drain, then re-fil. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #770280 26th Apr 2019 8:35pm
donmacn
Hi there,
This may or may not be relevant, as I don't know what axle breather/vent you might have fitted, but before you look at anything too technical, do make sure the water isn't getting in that way.
Check out this thread I started a little while ago
https://www.defender2.net/forum/topic66305.html - (sorry, don't know how to make it a link on the ipad) You can see the state of the 'oil' I took out of my rear axle.
The consensus was that it's coming in via the breather, so I've opted for the Gwyn Lewis breather kit to make sure that I don't get water in that way. To be fitted in the next little while. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #770285 26th Apr 2019 8:47pm
Tdi4
Thnx Guys! Some more things to look at Laughing
I’ll look at both your solutions. But i don’t need to flush the diff? I thought draining Will not remove all the oil??
But seriously thanx again for your advise. Just a pity a need so much lately. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #770291 26th Apr 2019 9:05pm
I'd flush the diff if my oil looked like that. Flushing is no more complicated than refilling with oil, taking it for a drive and then draining and refilling, though. Darren
Post #770298 26th Apr 2019 9:31pm
Tdi4
Using the same oil as regular? Or can i use a cheaper product for the flush? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #770299 26th Apr 2019 9:33pm
Moisture would still migrate up around the half shafts too.
If you did do what LRA mentioned you'd be best off leaving it for a while then change it over.
And yes, it'd need to be the same oil. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #770301 26th Apr 2019 9:42pm
Yes, using the same oil. A cheaper alternative would do the job but as it's almost impossible to completely drain an axle, the remainder would just dilute the new oil added later. To be honest, the cost of decent gear oil isn't excessive anyway. Darren
Post #770309 26th Apr 2019 10:06pm
Tdi4
To get back on your 2 posts. Just checked the rear diff pinion seal. Is too dirty to say for sure but the dirt is pretty greasy. So I think that's a culprit. I cleaned the diff and will look at it in a few days.
The breather look pretty okay. I will change it somewhere in the future but when I change the seal I'll put some sealant over it.
Post #770366 27th Apr 2019 12:21pm
