Home > Puma (Tdci) > How to remove gear from wiper assembly
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Because I had a stuck wiper I disassembled the dash (after 7 times i got quiet good at it Rolling with laughter ) and got the wiper assembly out. Everything was full of gunk so i thought to give everything a good clean and fresh Grease. But i can’t get the gear out of the wiper motor. Just bang harder Or is there a clever tip?
 a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #768949 17th Apr 2019 12:20pm
I don't think the big gear can be easily removed. When I last did one, I flushed it with degreaser in situ. Darren
Post #768952 17th Apr 2019 12:55pm
discomog
Like Anorak I tried this a few years ago and eventually decided it was not a serviceable item so just flushed it out with degreasant and repacked with grease before putting the cover back on.
I remember searching You Tube - there were plenty of instructions regarding overhauling the motor but nothing about removing the main gear. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #768968 17th Apr 2019 3:59pm
donmacn
Is this particular to newer vehicles? I know I've had one out of a Tdi-era Defender before. I don't remember any problems with that. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #768985 17th Apr 2019 7:36pm
Tdi4
It’s a puma 2008 wiper assembly. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #768987 17th Apr 2019 7:39pm
The one that I did was from a '92 Defender and looked pretty much identical to the OP's:
 Darren
Post #768999 17th Apr 2019 8:11pm
discomog
yep, mine looked exactly the same. Defender 90XS SW
Morgan Plus 8
Post #769009 17th Apr 2019 8:35pm
donmacn
Oh well, I'm afraid I can't help any further then.
I know I had mine removed because I had to relocate the nylon 'ramp' which activates the wiper stop switch (I think there are two places it can fit on the drive cog). I don't remember any real issues at all. I assume I removed the circlip on the wiring side, and tapped it through. Donald
in the past..
Post #769059 18th Apr 2019 8:32am
It looks to me like it's a press fit with a bearing in the outer housing, you would need a puller but as the fitting likely would have had the pressure applied to the centre of the gear I'd be concerned a puller putting force on the outer edges of the gear would bend it being weaker towards the extremity.
I'd would go with what LRA mentioned, and leave it in situ and flush it out and re-grease. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #769093 18th Apr 2019 11:56am
Retroanaconda
Earlier models had the gear retained by a circlip - looks like they've moved to a press-fit shaft.
Post #769120 18th Apr 2019 3:44pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I replaced the 1987 motor in my mini with a later unbranded version (2004)that looks very much like yours, and i'm sure the lucas version just pushed out, But that was 15 years ago since I did that. I don't think there made my lucas anymore anyway. 1953 80"
1987 mini city e
2011 90"
Post #769143 18th Apr 2019 9:31pm
Tdi4
Done it in situ. Thumbs Up
Next question. The new cable is longer than the old one. What to do? Leave it Or grind it?
Post #769181 19th Apr 2019 11:02am
donmacn
Maybe do you a swap if you can wait?? I bought a new one for my car - and it's too short! It was one of those 'this part has been superceded by...' things, so I just bought the latest one and it's too short for a Tdi.
It's unmolested in its packet....? Donald
in the past..
Post #769183 19th Apr 2019 11:35am
Tdi4
Sorry but i can’t wait. I’ve a puma and the complete dash is out for this repair. And i want to use the car for the weekend.
I’ve ordered it at LR direct if that’s any help a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #769185 19th Apr 2019 11:46am
donmacn
No worries! I appreciate that you'll want the car back together. Believe me, I can sympathise with that! Donald
in the past..
Post #769186 19th Apr 2019 11:48am
