![]() | Home > Puma (Tdci) > How to remove gear from wiper assembly |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Because I had a stuck wiper I disassembled the dash (after 7 times i got quiet good at it
![]() ![]() Click image to enlarge ![]() Click image to enlarge a defender from 1984 pretending to be a puma with a touch of Range Rover |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
I don't think the big gear can be easily removed. When I last did one, I flushed it with degreaser in situ. Darren
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1886 ![]() ![]() |
Is this particular to newer vehicles? I know I've had one out of a Tdi-era Defender before. I don't remember any problems with that. Donald
1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
It’s a puma 2008 wiper assembly. a defender from 1984 pretending to be a puma with a touch of Range Rover
The one that I did was from a '92 Defender and looked pretty much identical to the OP's:
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2539 ![]() ![]() ![]() |
yep, mine looked exactly the same. Defender 90XS SW
Oh well, I'm afraid I can't help any further then.
I know I had mine removed because I had to relocate the nylon 'ramp' which activates the wiper stop switch (I think there are two places it can fit on the drive cog). I don't remember any real issues at all. I assume I removed the circlip on the wiring side, and tapped it through. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20858 ![]() ![]() |
It looks to me like it's a press fit with a bearing in the outer housing, you would need a puller but as the fitting likely would have had the pressure applied to the centre of the gear I'd be concerned a puller putting force on the outer edges of the gear would bend it being weaker towards the extremity.
I'd would go with what LRA mentioned, and leave it in situ and flush it out and re-grease. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2739 ![]() ![]() |
Earlier models had the gear retained by a circlip - looks like they've moved to a press-fit shaft.
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 261 ![]() ![]() ![]() |
I replaced the 1987 motor in my mini with a later unbranded version (2004)that looks very much like yours, and i'm sure the lucas version just pushed out, But that was 15 years ago since I did that. I don't think there made my lucas anymore anyway. 1953 80"
1987 mini city e 2011 90" |
Done it in situ.
![]() Next question. The new cable is longer than the old one. What to do? Leave it Or grind it? ![]() Click image to enlarge a defender from 1984 pretending to be a puma with a touch of Range Rover |
Maybe do you a swap if you can wait?? I bought a new one for my car - and it's too short! It was one of those 'this part has been superceded by...' things, so I just bought the latest one and it's too short for a Tdi.
It's unmolested in its packet....? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Sorry but i can’t wait. I’ve a puma and the complete dash is out for this repair. And i want to use the car for the weekend.
I’ve ordered it at LR direct if that’s any help a defender from 1984 pretending to be a puma with a touch of Range Rover |
No worries! I appreciate that you'll want the car back together. Believe me, I can sympathise with that! Donald
