Home > Maintenance & Modifications > Hardtop loadsoace matting options
dexter
United Kingdom 2011 Defender 90 Puma 2.4 HT Keswick Green
I need a new loadspace mat for a Puma 90 Hardtop, is the Exmoor Trim option worth considering? A bit of sound proofing would be good but not essential, non slip is essential.
Post #768277 12th Apr 2019 2:14pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
I cut down a thickish (3/4 inch roughly) rubber stable mat for the back of my old 110 300tdi Hardtop, certainly non slip and damped the noise down alot. Cheaper than most alternatives as well.
Post #768305 12th Apr 2019 5:28pm
gcc130
I also used stable matting from my local country store, two thicknesses available, I used the thinner one.
I think it was about £40/sheet a couple of years ago.
Post #768316 12th Apr 2019 7:22pm
williamthedog
Thats what i use in the back of my pick up to give the dogs a bit of cushioning from the chequer plate. Definitely non slip. Thumbs Up
Post #768318 12th Apr 2019 7:23pm
deaallen
United Kingdom 2012 Defender 90 Puma 2.2 SW Santorini Black
I got some pre cut, checker plate effect plastic matting with the edges hemmed for £10 from Newbury 4x4 show last weekend. I'm very happy with it , especially for the price. I plan on fitting the rear with soundproofing and carpet soon to go under it
Post #768321 12th Apr 2019 7:45pm
LR Sam
watching with interest - horse matting sounds the ideal solution - is it easy to cut? A friend recommended gym interlocking mats.
I have linexed my floor but my dog slips on the surface - it doesn't scratch it but isn't handy for her.
Post #768344 12th Apr 2019 9:47pm
shropshiredefender
Cut mine with a carpenters hand saw
Post #768350 12th Apr 2019 10:24pm
Grouse
+2 and it made a massive difference to sound deadening
Post #768376 13th Apr 2019 8:43am
kaney
United Kingdom 2005 Defender 90 Td5 CSW Epsom Green
I used a sound insulation and then added ply wood which i screwed down although i do use it for work ie mowers etc but you then could put a mat on top
Post #768383 13th Apr 2019 9:36am
Retroanaconda
I have a piece of rock crusher conveyor belt in mine. 3/4” or so thick and very heavy.
Same principle as the stable matting, but free Very Happy
Post #768414 13th Apr 2019 2:24pm
discomog
Stable matting is a good idea for load area flooring but it is heavy, an advantage 'cos it doesn't move around but it is not the easiest material to cut. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #768440 13th Apr 2019 6:55pm
