![]() | Home > Maintenance & Modifications > Hardtop loadsoace matting options |
| shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 835
I cut down a thickish (3/4 inch roughly) rubber stable mat for the back of my old 110 300tdi Hardtop, certainly non slip and damped the noise down alot. Cheaper than most alternatives as well.
| gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 790 |
I also used stable matting from my local country store, two thicknesses available, I used the thinner one.
I think it was about £40/sheet a couple of years ago. |
| williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441
Thats what i use in the back of my pick up to give the dogs a bit of cushioning from the chequer plate. Definitely non slip.
| deaallen Member Since: 15 Feb 2016 Location: Basingstoke Posts: 267
I got some pre cut, checker plate effect plastic matting with the edges hemmed for £10 from Newbury 4x4 show last weekend. I'm very happy with it , especially for the price. I plan on fitting the rear with soundproofing and carpet soon to go under it
| LR Sam Member Since: 08 Nov 2012 Location: Yorkshire Posts: 236
watching with interest - horse matting sounds the ideal solution - is it easy to cut? A friend recommended gym interlocking mats.
I have linexed my floor but my dog slips on the surface - it doesn't scratch it but isn't handy for her. |
Cut mine with a carpenters hand saw
| Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 538 |
+2 and it made a massive difference to sound deadening |
| kaney Member Since: 01 Oct 2018 Location: Bolton Posts: 232
Click image to enlarge I used a sound insulation and then added ply wood which i screwed down although i do use it for work ie mowers etc but you then could put a mat on top Click image to enlarge |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2789
I have a piece of rock crusher conveyor belt in mine. 3/4” or so thick and very heavy.
Same principle as the stable matting, but free |
| discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2544
Stable matting is a good idea for load area flooring but it is heavy, an advantage 'cos it doesn't move around but it is not the easiest material to cut. Defender 90XS SW
| All times are GMT |
