![]() | Home > Technical > Interior LED question |
We have the Nakatanenga interior LED lights in our 1996 Defender as well as our Pumas and no problems with them glowing. They work fine.
Brendan |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1898 ![]() ![]() |
Thanks for that Brendan and tempting as it is to press ahead, my concern is that it appears some vehicles (including mine) 'glow' with just an LED bulb replacement and others do not, so based on previous replies I am just wondering if I can be confident changing the whole light unit will avoid the problem which I rather gather comes from further down the line, but I could easily be wrong as changing a fuse is just about the limit of my electrical/electronic skill . . . . . . .
Hi CM, please do not confuse the Nakatenga interior LEL light unit with a cheap led 'bulb'
It has a proper circuit board in, also ability to switch to red light to save your night time vision. We have sold lots of these units without a single complaint (quickly touching wood) Before the current trip I am on we replaced both non working nearly 21 year old original fittings with the Nakatanenga ones and they work fine. Now if there was going to be any issues I would expect it on our 110 as both original lights were corroded and fubar. If you decide to go ahead and there are any issues just return them for a full refund. Brendan |
Brendan
Thanks for the reply and apologies if I appeared to be comparing a £3 bulb to a £76 complete unit ![]() I gather it may be the electronic wizardry on some of the Puma's that creates the issue, but can't go wrong with your offer to return, so will get on with an order, which may be followed by another when I eventually get around to fitting my new rear headlining ![]() ![]() Rob Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 ![]() ![]() ![]() |
Just fitted the Fourby led "bulbs" and working perfectly in my 2.4 Puma. Not bad for a tenner and a spare included.
Tip of the day, pull the fuse before fitting, somehow my finger touched something and blew the fuse. |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
It's the way the later Siemens alarm module controls the interior lamps. There is a small amount of voltage leakage. The same leakage happens with the standard festoons, it's just that you don't see it
![]() Only happens on the 2.2 ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
oops. posted on wrong topic!! My bad!!! |
X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212 ![]() ![]() ![]() |
Sorry to resurrect an old thread but can anyone confirm what the options are for those of us with a 2.2 Puma?
I'd like to try some of the LED bulbs (I want the end result to look original so I don't fancy the MUD/Nakatenanga alternatives). I've read various threads on here and I'm still none the wiser as to what the options are... plenty say these work for me but it's not always clear if they are in a 2.4 or a 2.2. So, can anyone who has successfully changed the interior bulbs on a 2.2 please post up a link to some suitable bulbs that work without the dim residue light showing, or if it's not possible confirm to that effect. Many thanks in advance ![]() |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4316 ![]() ![]() ![]() |
There’s is nothing fancy about the 2.2 compared to 2.4. If works on one it’ll work on the other. 2007 110 TDCi Station Wagon XS
Sorry, how is that the case based on this statement that the 2.2 is different? |
I may be wrong
Ihod Member Since: 07 Nov 2015 Location: Berkshire Posts: 165 ![]() ![]() ![]() |
I installed these: https://www.conrad.com/p/diodor-led-eec-a-...pcs-704320 Not the cheapest LED around but they are warm white (the colour of the existing incandescent bulb) but produce a lot of good quality even light in the van. Low current draw, low consumption and no 'glow' when in any switch position (other than on!). Exactly what LR should have installed.... Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
Perfect, I'll give them a whirl, thanks for confirming
I, too, have fitted the Diodor bulbs from Conrad and they're superb. The best interior lighting I've seen.
![]() Click image to enlarge ![]() Click image to enlarge As an aside, in the discussion above regarding 2.2's, everybody is sort of right. Later 2.2's (post '14?) are fitted with a Siemens alarm module that's different from the earlier Lucas. However, the voltage leakage that affects cheap LED's occurs in earlier models than that, both 2.2 and 2.4. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
