Home > Technical > Interior LED question
Page 2 of 3 <123>
CarMan
I'm presuming if I change the whole fitting e.g. for the Nakatanenga one I would like, I will still have the same problem - if so I'll just stick with standard sadly Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #635939 6th Jul 2017 12:35pm
leeds
We have the Nakatanenga interior LED lights in our 1996 Defender as well as our Pumas and no problems with them glowing. They work fine.
Brendan
Post #635964 6th Jul 2017 3:01pm
CarMan
Thanks for that Brendan and tempting as it is to press ahead, my concern is that it appears some vehicles (including mine) 'glow' with just an LED bulb replacement and others do not, so based on previous replies I am just wondering if I can be confident changing the whole light unit will avoid the problem which I rather gather comes from further down the line, but I could easily be wrong as changing a fuse is just about the limit of my electrical/electronic skill . . . . . . .
Post #635978 6th Jul 2017 4:16pm
leeds
Hi CM, please do not confuse the Nakatenga interior LEL light unit with a cheap led 'bulb'
It has a proper circuit board in, also ability to switch to red light to save your night time vision.
We have sold lots of these units without a single complaint (quickly touching wood)
Before the current trip I am on we replaced both non working nearly 21 year old original fittings with the Nakatanenga ones and they work fine. Now if there was going to be any issues I would expect it on our 110 as both original lights were corroded and fubar.
If you decide to go ahead and there are any issues just return them for a full refund.
Brendan
Post #636027 6th Jul 2017 7:51pm
CarMan
Brendan
Thanks for the reply and apologies if I appeared to be comparing a £3 bulb to a £76 complete unit Embarassed
I gather it may be the electronic wizardry on some of the Puma's that creates the issue, but can't go wrong with your offer to return, so will get on with an order, which may be followed by another when I eventually get around to fitting my new rear headlining Whistle
Thumbs Up
Rob Rob
Post #636247 7th Jul 2017 4:40pm
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
Just fitted the Fourby led "bulbs" and working perfectly in my 2.4 Puma. Not bad for a tenner and a spare included.
Tip of the day, pull the fuse before fitting, somehow my finger touched something and blew the fuse.
Post #636852 10th Jul 2017 9:12pm
grafty99
It's the way the later Siemens alarm module controls the interior lamps. There is a small amount of voltage leakage. The same leakage happens with the standard festoons, it's just that you don't see it Thumbs Up
Only happens on the 2.2 Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #636861 10th Jul 2017 9:43pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Cupboard wrote:
The door switches have nothing to do with it, at least on a modern Defender.
All the door switches do is talk to the 10AS alarm unit, which then does all the control of the interior lighting. The glowing LEDs is a feature of the 10AS.
oops. posted on wrong topic!! My bad!!!
Post #659658 25th Oct 2017 7:54pm
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Sorry to resurrect an old thread but can anyone confirm what the options are for those of us with a 2.2 Puma?
I'd like to try some of the LED bulbs (I want the end result to look original so I don't fancy the MUD/Nakatenanga alternatives).
I've read various threads on here and I'm still none the wiser as to what the options are... plenty say these work for me but it's not always clear if they are in a 2.4 or a 2.2.
So, can anyone who has successfully changed the interior bulbs on a 2.2 please post up a link to some suitable bulbs that work without the dim residue light showing, or if it's not possible confirm to that effect.
Many thanks in advance Thumbs Up
Post #766976 5th Apr 2019 9:47am
Bluest
There’s is nothing fancy about the 2.2 compared to 2.4. If works on one it’ll work on the other. 2007 110 TDCi Station Wagon XS
Post #766979 5th Apr 2019 10:10am
X4CAC
Sorry, how is that the case based on this statement that the 2.2 is different?
Post #766985 5th Apr 2019 10:35am
Bluest
I may be wrong Embarassed 2007 110 TDCi Station Wagon XS
Post #766986 5th Apr 2019 10:42am
Ihod
United Kingdom 1998 Defender 90 300 Tdi ST Rioja Red
I installed these:
https://www.conrad.com/p/diodor-led-eec-a-...pcs-704320
Not the cheapest LED around but they are warm white (the colour of the existing incandescent bulb) but produce a lot of good quality even light in the van. Low current draw, low consumption and no 'glow' when in any switch position (other than on!).
Exactly what LR should have installed.... Ian
MY1998 300Tdi 90 Hard Top (Now Soft Top)
MY2015 110 XS SW - Sold
MY2008 110 County USW - Sold
MY1962 Series IIa Truck Cab - Sold
MY1994 300Tdi 90 Hard Top - Sold
MY2001 TD5 90 Truck Cab - Sold
Post #766991 5th Apr 2019 11:00am
X4CAC
Perfect, I'll give them a whirl, thanks for confirming Thumbs Up
Post #766992 5th Apr 2019 11:06am
I, too, have fitted the Diodor bulbs from Conrad and they're superb. The best interior lighting I've seen.
As an aside, in the discussion above regarding 2.2's, everybody is sort of right. Later 2.2's (post '14?) are fitted with a Siemens alarm module that's different from the earlier Lucas. However, the voltage leakage that affects cheap LED's occurs in earlier models than that, both 2.2 and 2.4. Darren
Post #766996 5th Apr 2019 11:39am
Page 2 of 3 <123>
