![]() | Home > Off Topic > 2.2 transit engine that's very broken... |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
A single injector that's flowing like a hosepipe will give the symptoms you describe. I'd be tempted to chuck a recon injector in to see if it runs as normal before diagnosing a dead engine.
![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5374 ![]() ![]() |
I would do the same, put a recon injector engine in before going to the hassle of finding a decent replacement engine. Laugh is I would check the electrics 1st on the loom in case there is crap, My mates Vectra started to run odd, and nearly had to do the same thing, until he checked the loom for the injectors and found that there was a bit of corrosion, five mins later and the car was running like a dream. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654 ![]() ![]() ![]() |
White smoke can be caused by over fuelling. I'd also be looking at a injector.
Even one from a scrappy if money is tight 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 ![]() ![]() |
A replacement injector was tried. Engine sounds like a bag of spanners still. I was doubting myself that one injector could cause runAway like over-revving, hence why I asked you guys. But being able to stop it on the key does point to this.
I had suggested the over fuel and revving could have holed or cracked a piston. V8 90...WIP |
I'd be dropping the engine oil out and looking for copper or brass looking bits, or just metal in general.
If its proper over revved it could have ![]() I've blown many a race bike over the years and the oil usually gives you a idea 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
last transit I had to drive with Engine sounds like a bag of spanners through piston out end up being tow to fords bottom end rebuild, fords had back of there work shop stacked high with wooden crates all with 2.2 transit short engine good luck
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751 ![]() ![]() ![]() |
Did they do a compression test on the cylinders?
I don't know bud but I think the garage is reputable so guess they would have.
My friend is not wanting to take chances or throw good money after bad so he is going for a new engine I believe. He just wanted peace of mind over the cause. I have told him next time it happens to not put the van into neutral when he stops! V8 90...WIP |
