![]() | Home > Technical > Could this be causing an ABS issue? |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I would say it might well be. If its not the ring then it could be damage to the sensor.
Something had jammed in there and ground away at the ring, its likely there will be damage to the sensor as well ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751 ![]() ![]() ![]() |
Looks like something has jammed in there.
I've always wondered what these actually do. Are they essential? |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2225 ![]() ![]() ![]() |
The sensor looks alright, slight score but nothing that looks really bad.
The are what the ABS sensors read. Ive cleaned the sensor,, plug and ring issue remains. Has been intermitant since I got back from a very wet Salisbury. Worth replacing the sensor? |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3748 ![]() ![]() ![]() |
Can you adjust the sensor to close the gap up? There may well have been something in there that has opened up the gap between the sensor and the castellated disc. This would explain the scoring and the alarm.
Dont know tbh. Far as I know its just push it in till it stops.
LinDens90XS Member Since: 25 Feb 2012 Location: Merseyside Posts: 83 ![]() ![]() |
My near side front has always had a problem and my fix is to tap the sensor back in gently with a piece of wood and hammer, don’t overdo it, it resets and works fine until it raises up again. Hope this helps. Regards
Dennis. |
