![]() | Home > Maintenance & Modifications > Having a crisis about rust after warranty expires |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1068 ![]() ![]() ![]() |
Last year the paint around the windscreen bubbled, so was fixed under warranty.
12 months on, it's back in exactly the same space. Reasonable to assume LR in Hull bodged it in the same way they bodged the other work. I'll try York this time to see how they get on. What I'm worried about is what happens when the warranty has expired. Can anyone give me an idea of how much something like this would cost to have repaired by a decent independent? That is, done properly with some sort of anti-corrosion behind the metal. Thanks |
Did you vehicle warranty run out or you paint warranty run out? Russell
2011MY 110 XS USW Black |
Paint warranty is still valid (not 5 years old yet). I'm just concerned how much this is likely to cost me next time.
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751 ![]() ![]() ![]() |
All the main dealer does is call the local “chips away” mobile paint guy who rocks up and does the quickest repair that looks ok. None have Bodyshops, media blasters, spray booths etc.
This means you’re in a continual warranty loop as they are probably painting over the corrosion. Personally I’d bite the bullet and pay for a proper repair. |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5355 ![]() ![]() |
It just shows you how cheap things are made, If they can get away with only putting minimal amount of paint on they will! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
the best advice I can give is - don't fight it.
buy a deck chair and just sit back and watch it rot ![]() sorry but I've concluded the only answer is to get bits done as and when (preferably early stages) - and that's that. |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
It's a good point though, done properly it should last longer. I've 2 years on a windscreen frame under warranty and the screen was removed by a body shop - touch wood it's still OK. Isn't the frame also aluminium which is harder to paint? 2014 Keswick Utility 2.2
be the quality of paint and who painted it, Where I work they get agency painters in some are good some just don't give a toss. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
