Home > Maintenance & Modifications > Having a crisis about rust after warranty expires
AMBxx
Last year the paint around the windscreen bubbled, so was fixed under warranty.
12 months on, it's back in exactly the same space. Reasonable to assume LR in Hull bodged it in the same way they bodged the other work.
I'll try York this time to see how they get on.
What I'm worried about is what happens when the warranty has expired. Can anyone give me an idea of how much something like this would cost to have repaired by a decent independent? That is, done properly with some sort of anti-corrosion behind the metal.
Thanks
Post #766234 31st Mar 2019 1:20pm
Oldowner
The proper way to fix this is to remove the screen frame entirely, remove the screen from the frame, media blast the frame and then repaint it with proper etch primer first. Even then you can still get issues due to the construction of the frame, it is made out of four pieces that are slotted together then welded from the rear - you get corrosion between the pieces where they are butted together.
A body shop will most likely just flat back the corrosion in situ, repaint it and hope for the best.
Some defenders are worse than others - I have in my garage a screen frame from a 1990 defender in perfect condition that I have saved to fit to my Puma.
Post #766264 31st Mar 2019 6:02pm
BigRuss
Did you vehicle warranty run out or you paint warranty run out? Russell
2011MY 110 XS USW Black
Post #766272 31st Mar 2019 7:12pm
AMBxx
Paint warranty is still valid (not 5 years old yet). I'm just concerned how much this is likely to cost me next time.
Post #766338 1st Apr 2019 7:35am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
All the main dealer does is call the local “chips away” mobile paint guy who rocks up and does the quickest repair that looks ok. None have Bodyshops, media blasters, spray booths etc.
This means you’re in a continual warranty loop as they are probably painting over the corrosion.
Personally I’d bite the bullet and pay for a proper repair.
Post #766341 1st Apr 2019 7:49am
Procta
It just shows you how cheap things are made, If they can get away with only putting minimal amount of paint on they will! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #766401 1st Apr 2019 5:48pm
Caterham
the best advice I can give is - don't fight it.
buy a deck chair and just sit back and watch it rot
Rolling with laughter
sorry but I've concluded the only answer is to get bits done as and when (preferably early stages) - and that's that.
Post #766411 1st Apr 2019 6:30pm
UtilityTruck
It's a good point though, done properly it should last longer. I've 2 years on a windscreen frame under warranty and the screen was removed by a body shop - touch wood it's still OK. Isn't the frame also aluminium which is harder to paint? 2014 Keswick Utility 2.2
Post #766412 1st Apr 2019 6:34pm
Procta
be the quality of paint and who painted it, Where I work they get agency painters in some are good some just don't give a toss. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #766415 1st Apr 2019 7:01pm
