Home > Maintenance & Modifications > Replacement steering wheel grief.
Page 2 of 3 <123>
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
In the hope of saving you some more potential heartache there are two types of Mountney pattern:
The Classic range which is 101PCD
The M range which are 70 PCD alla MOMO OMP and many copies.
Hope this helps. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #598655 2nd Feb 2017 7:19pm
petestaunch
United Kingdom 2008 Defender 110 Puma 2.4 HT Keswick Green
Thank you all. Much appreciated!
Post #598779 3rd Feb 2017 10:54am
X4SKP
Hope this helps.
That's the information needed...i'd say that pete's wheel is The Classic range which is 101PCD...From the photo...but measure twice order once... Exclamation SKIP
Post #598781 3rd Feb 2017 11:19am
300TDi CSW Phil
As a general rule the bolt patterns will give away the boss type as follows:
One bolt top dead centre of mounting will invabiably be 70 PCD MOMO, OMP, Sparco, Mountney M Series etc
Two bolts off centred at top on a small PCD of 74 Nardi, Personal, Raid and a few others
Two bolts at top on larger PCD of 101 Mountney Classic
9 bolt pattern looks to be Moto Lita only.
There are companies that make a conversion ring to fit a 70 PCD wheel to a 74PCD boss and vice versa.
Oh no I've turned into a steering wheel geek. Sad 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #598995 4th Feb 2017 9:04am
CallumB
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
Is that table correct??
X4SKP wrote:
Hello petestaunch
A 2008 Station Wagon looks to be a 36 Spline...but the Steering Wheel looks good so maybe source a replacement Boss and you can use it...check the PCD (Hole Positions) for any swap over Boss, pairing it to your Wheel
Good Luck
Going back to an old post, but I was just about to start ordering a 48 spline boss for my 2007 Puma 90 Van based on that table, but thought I'd just check and found I've got 36 splines! Maybe I've had a new steering column...it was involved in a front ender before my time. Worth checking each time, especially as it's a 2 minute job I guess!
Post #764463 20th Mar 2019 3:02pm
Martin
Site Admin
That chart is an old one without the 2015/16MY update.
Original table at http://www.web-rover.co.uk/articles-steeringwheels.html
It "should" have a 48 spline column, but you've done the right thing by checking Thumbs Up
What style is the wheel?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #764464 20th Mar 2019 3:11pm
CallumB
Hi Martin, thanks. It's a standard LR wheel which is now well worn and smooth/slippy. Looking to replace with something with a better feel and slightly smaller size. Reading the posts, I'll go for near original 15" but security has me bothered and I'm currently on Optimill's website looking at the quick release bosses - not cheap but probably more secure than my Stoplock Pro.
Post #764465 20th Mar 2019 3:20pm
Martin
Site Admin
Is it the type with the foam pad in the centre or where you remove the badge to get to the nut?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #764466 20th Mar 2019 3:22pm
CallumB
It's got the foam pad but there's no removable badge - the whole pad pulls off to expose the nut if that makes sense?
Post #764468 20th Mar 2019 3:30pm
Martin
Site Admin
Sounds like the column has been changed in the past for some reason (perhaps to fit that wheel).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #764474 20th Mar 2019 3:57pm
CallumB
Changed due to the accident I would think. That said, it looks like a standard wheel just like this:
Post #764477 20th Mar 2019 4:14pm
Martin
Site Admin
It's a Station Wagon wheel though, so very unusual to be fitted on a hardtop between 1998 and 2014 Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #764478 20th Mar 2019 4:16pm
CallumB
Aha! Thanks again Martin. Very helpful. I've learned something else about my truck today! Thank god I checked before ordering the boss. I had no idea that was a station wagon wheel.
Post #764479 20th Mar 2019 4:19pm
CallumB
Steering wheel removal
Me again! I am now the proud owner of a Optimill quick release boss and swivel lock (very very nice pieces of engineering). It would be really nice to fit them onto my truck if only the old steering wheel would come off. I've manufactured a puller, doused penetrating oil on the splines but the wheel will not come off. I left the puller on tension over night and still no movement. I've torqued it to the point the 5mm bolts are bending over. I haven't seen anything posted about anyone having this much grief. Any ideas short of removing the column?! Thanks.
UPDATE: Spoke to Tony Cable at TJC Landrover, he advised to use a mallet on back of steering wheel (left and right) whilst keeping tension on with the puller. I'd used both methods separately but not together. After about 10 mins of walloping the wheel came off - thanks Tony! Very chuffed with all the stuff Optimill supplied - so nice to be rid of that awful LR wheel.
Post #765914 29th Mar 2019 10:37am
L110CDL
Glad you won the battle with the steering wheel Thumbs Up
Looking good with the new steering wheel Very Happy Clayton.
Keeper.
Post #766741 3rd Apr 2019 9:52pm
Page 2 of 3 <123>
