Home > Maintenance & Modifications > Installing a aux power socket in the rear
Page 10 of 11 <123 ... 91011>
From around 2013 the purple wire was deleted from the standard loom. To re-create the arrangement, it's necessary to tap into the constant live that forms part of the towing electrics. This is typically concealed behind the plastic flap that protects the rear of the lower lights at the back of the wheel arch.
Alternatively, you can run a separate feed directly from the battery box, which is what I've done:
 Darren
Post #719967 27th Jul 2018 2:27pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Just got round to doing this today, I've found the 12v supply behind the dirt cover I just need to know what type of connector this round one is to do the job properly/neatly. I could just cut it and crimp a wire to it but I'd rather keep it reversible and correct. It was fitted with a red plastic bung.
Car is a 2001 td5 90 csw FYI
Post #752577 20th Jan 2019 12:17pm
It could be a bullet connector but I'd still be tempted to cut it off and extend it with a soldered joint up into the rear of the light cluster. Darren
Post #752665 20th Jan 2019 8:05pm
LandymanStefan
Joined the club
Post #754076 26th Jan 2019 4:11pm
driver
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Have followed this thread and installed an accessory socket as described which all went well,
Problem I have is there seems to be a significant voltage drop somewhere between the 20 amp fuse and the accessory socket,
At the fuse it registers 12v but at the trailer socket it registers 6v also 6v at the accessory socket? the trailer socket operates correctly,
Anyone have any ideas?
Post #765477 26th Mar 2019 2:53pm
driver
Any help on this one?
Post #766021 29th Mar 2019 10:58pm
It sounds like you've got an earth fault somewhere. Unfortunately, it's time to get the multimeter out and start checking continuity. Darren
Post #766022 29th Mar 2019 11:16pm
driver
Thanks, that's what I was thinking as well, will give it a go tomorrow.
Post #766025 29th Mar 2019 11:42pm
Emptywallet
United Kingdom 2005 Defender 110 Td5 CSW Tonga Green
i need to tap off the tow bar loom under the the rear of the car. My question is what is the easiest way to get my feed into the inside of my 110 CSW?
Have to say I was somewhat disappointed to find I did not have spare purple and black wired connector behind the trim panel.
Post #797317 8th Oct 2019 8:12pm
Up through the rubber grommet in the top of the wheelbox behind the rear lights.
I'm very surprised that you haven't found the purple wire. My old '05 110 station wagon certainly had it. Darren
Post #797328 8th Oct 2019 8:56pm
Emptywallet
Thank you 🙏
Post #797329 8th Oct 2019 8:58pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Here is my approach to get permanent live from a Puma's 13-pin tow loom:
https://www.defender2.net/forum/post853654.html#853654
Post #853656 1st Sep 2020 6:45pm
Gasket
Joining the club
Perfect! Love this forum.
We've just been walking the dog and planning our trip up to the western isles in a couple of weeks and saying how nice it would be to have an electric coolbox in the back of our 2010 90 SW. Said I'd look it up and lo-and-behold: this thread!
I've got one shot to fit it on the morning of the 12th, so need to order everything in advance.
Sadly, Erik's pics in the original post have disappeared - does anyone have an archive set of photos?
I think all I need to order are:
1) EYQ100130 (plastic rivets) - ORDERED (am fitting rear speakers at the same time, so expecting these to break)
2) A suitable 12v socket, this one looks perfect and is mentioned above https://www.flatdoguk.com/showdetails.asp?id=1439
3) some suitable wire
4) Four M5 (?) countersunk bolts and nuts (already have)
5) spade connectors/crimps/tools - ALREADY HAVE.
Is there an idiot's guide anywhere to making this come on with the ignition so I don't get a flat battery? I saw the one post above with a relay which looked neat, but I'm a numpty when it comes to electrics.
Post #853887 2nd Sep 2020 7:42pm
nitram17
These threads are great but a picture is a great help ....its a shame that there could not be a way of keeping all the pictures on a sticky thread.?
Post #965846 23rd Sep 2022 10:53pm
For some reason, some folks seem to delete their pictures after a while, which is pretty frustrating. Darren
Post #965903 24th Sep 2022 8:02pm
