Home > Technical > Rear trim removal quick question
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
Seems like it would be easy but I’m trying to remove the trim around both rear windows. I’m starting with the corner bit that looks like it’s held in place with some capped small rivets. See pic.
How do I remove trim? Must drill these out?
Post #729669 17th Sep 2018 11:38pm
zsd-puma
The trim around the small rear windows, just pulls off, it has spring clips that grip the body seams, just give it a good pull.
The large side window trims, have two large plastic trim clips that pull out at the bottom, they may be obscured by the 3rd row seats. Once they're off the trim lifts off the cant rail (internal gutter) at the top, it just hooks on. Depending on configuration, you may need to unbolt seat belts to feed them through holes in the trim.
Post #729671 18th Sep 2018 12:46am
big110
Thx. Do you know how the grab handle is secured?
Post #729672 18th Sep 2018 1:02am
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
The handles are with 4 screws, just clip the covers off from the handle side and they flip open (if the plastic is not broken)
Also take a look herehttps://www.landroverworkshop.com/diagrams...trim_45032 Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #729680 18th Sep 2018 6:59am
Those trims also have a third fir tree fixing on the front leading edge, within the reveal of each rear side door.
To remove them completely, it's also necessary to unbolt the lower fixing of the second row seat belts, as they're threaded through the panel. The nut is captive though, so it's very easy to remove the bolt from above. Darren
Post #729695 18th Sep 2018 8:32am
big110
Thank you all for the assist, trim is off and now on to trying to get the bloody windows out!
Post #729852 18th Sep 2018 11:33pm
zsd-puma
I think the later (TD5/Puma) rear side windows are bonded.
One of these might help.
https://www.ebay.co.uk/itm/Windshield-Remo...2486011073
Post #729916 19th Sep 2018 4:55pm
G4UJS
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
excellent post, very helpful, Thanks Smile
Post #764343 19th Mar 2019 8:01pm
