![]() | Home > Technical > Rear trim removal quick question |
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
The trim around the small rear windows, just pulls off, it has spring clips that grip the body seams, just give it a good pull.
The large side window trims, have two large plastic trim clips that pull out at the bottom, they may be obscured by the 3rd row seats. Once they're off the trim lifts off the cant rail (internal gutter) at the top, it just hooks on. Depending on configuration, you may need to unbolt seat belts to feed them through holes in the trim. |
| big110 Member Since: 02 Nov 2016 Location: Worldwide Posts: 409
Thx. Do you know how the grab handle is secured?
| Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236
The handles are with 4 screws, just clip the covers off from the handle side and they flip open (if the plastic is not broken)
Also take a look herehttps://www.landroverworkshop.com/diagrams...trim_45032 Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Those trims also have a third fir tree fixing on the front leading edge, within the reveal of each rear side door. To remove them completely, it's also necessary to unbolt the lower fixing of the second row seat belts, as they're threaded through the panel. The nut is captive though, so it's very easy to remove the bolt from above. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thank you all for the assist, trim is off and now on to trying to get the bloody windows out!
I think the later (TD5/Puma) rear side windows are bonded.
One of these might help. https://www.ebay.co.uk/itm/Windshield-Remo...2486011073 |
| G4UJS Member Since: 20 Jan 2019 Location: Shropshire Posts: 226
excellent post, very helpful, Thanks
| All times are GMT |
