Home > Puma (Tdci) > Broken down in France again and now UK.....VERY not happy...
Page 1 of 6 123456>
johnnyd
Hi all, I really do not believe this, truck broke down in France last August after ferry trip over here, it has been fine since then back in Enlgland, no issues at all, was on the ferry yesterday, drove to the house we are staying at fine, went to start it this morning, and 4 turns then nothing, no fire. See last years post by me around August time, the symptoms are exactly the same. I have no internet access apart from this phone. What the hell is it? Last time it started the next day after it was towed to the B and B the night before. Any help much appreciated. Should the crank sensor drop to zero on ignition 2 position? Have reprogrammed key fobs, really Censored off I have to say. 2008 TDCi 2.4 XS CSW
Post #764136 18th Mar 2019 2:16pm
diduan
Bulgaria
Try to take out the main relais undet the right seat and put it in again. This always helped mine start. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #764143 18th Mar 2019 2:49pm
MK
Yes relays and check battery terminals and grounds. Puma 110" SW
Post #764145 18th Mar 2019 2:53pm
Stacey007
Starter relay is under seat wiggle them and make sure ok,
Is immobiliser coming off?
Post #764155 18th Mar 2019 3:22pm
johnnyd
Thanks for the replies, wiggled relays under right seat and in fuse box under steering column, still the same, I believe the Immobilier is coming off, the red light extinguished on the dash, still just 4 turns and no fire, then cut out. 2008 TDCi 2.4 XS CSW
Post #764160 18th Mar 2019 3:50pm
DG123
Sounds like immobiliser problem - I got recovered a couple of times in my D2 with those symptoms and it started first time when unloaded from the truck Confused
The same D2 also loved France and never wanted to leave - broke down every year for three years; sold it for the Puma in the end. 2012 110 XS SW Orkney Grey
2003 D2 Td5 Black [SOLD]
Post #764161 18th Mar 2019 3:53pm
johnnyd
Can anyone post detailed instructions on how I get to this instrument cluster plug, I am heavily suspecting that, I have no tools, only a leatherman, but I will see if I can buy some tomorrow.. like I say I can’t tether this iPhone connection to my Mac or iPad, iPhone googling and searching is really tricky on a small screen, might se if I can walk to a bar later and get WiFi. 2008 TDCi 2.4 XS CSW
Post #764162 18th Mar 2019 4:08pm
Martin
Site Admin
Detailed PM under construction...  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #764164 18th Mar 2019 4:27pm
Martin
Site Admin
Sent  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #764166 18th Mar 2019 4:32pm
johnnyd
Well guess what, Martins detailed instructions were fantastic and by fate I had a torx set in the cubby box I did not know were there lol......did what Martin recommended, and it started first time, that was a temporary fix with no instrument cluster installed, so I need to find some wire cutters and a small choc a block from somewhere tomorrow.
I am assuming the ferry ramps or cobbled streets in the place we are staying have caused this fault to resurface again, odd it only happens in France lol
Martin is a hero and I owe him beers 🍺
Thanks to all who replied.
JD 2008 TDCi 2.4 XS CSW
Post #764180 18th Mar 2019 7:17pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Without going into too much detail, I'm guessing this is now a confirmed immobilizer problem which you've just bypassed behind the cluster?
I like to know these things just in case I find myself or another in a similar circumstance.
Post #764184 18th Mar 2019 7:39pm
johnnyd
From what Martin has explained to me, it is not bypassing the immobiliser , but bypassing the Immobilier ‘diversion’ through the cluster. 2008 TDCi 2.4 XS CSW
Post #764193 18th Mar 2019 8:21pm
Martin
Site Admin
Indeed Smile
It does NOT bypass the immobiliser, it just removes the instrument pack from the circuit. The 2.2 are wired like this (no instrument pack in the circuit).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #764194 18th Mar 2019 8:23pm
johnnyd
How nice of LR to increase the possible points of failure on an off road vehicle..... Big Cry 2008 TDCi 2.4 XS CSW
Post #764199 18th Mar 2019 8:44pm
ickle
France is a big place, but just on the off chance where are you?
Post #764256 19th Mar 2019 8:36am
Page 1 of 6 123456>
