Home > Td5 > Defender TD5 cruise control.....confused!
Page 4 of 5 <12345>
lightning
AJC wrote:
I’m now up & running. Thanks to Harry & Grafty
Can l ask you where you got that switch with the motorway symbol, or the part number?
I ordered what l thought was the right one, and ended up with a Discovery 2 switch which is the wrong shape.
Post #721648 6th Aug 2018 8:58am
mk1collector
I’m guessing that question was aimed at me. I made the switch, no one sells one at the moment. See my build thread below for a couple of pics how I did it. Ray
My build thread
Post #721791 6th Aug 2018 7:01pm
lightning
Thanks for the link, but there’s 67 pages on that thread!
Can you tell me what page it’s on?
Cheers.
Post #722465 9th Aug 2018 10:07am
mk1collector
Rolling with laughter I’ve only done it recently so it’s on page 64, I took a black switch cover from my defender drilled a little hole for the light then put it on the discovery switch then pics of how I got the motorway decal on are on page 64 Thumbs Up Ray
My build thread
Post #722534 9th Aug 2018 5:45pm
excossack
Digging up and old thread here...Do all TD5's support Cruise control ? Mine is a Jan 99' model. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #762927 11th Mar 2019 8:52pm
lightning
I think it’s post 2001 when they changed the ECU.
But not 100% sure.
I fitted the Nakatanenga kit to my 2005 TD5 Defender and it works fine.
The kit costs just over £100
But for some reason it’s not listed on the UK site, only the German one. The instructions are in German but they sent me English ones on a PDF file.
Post #763080 12th Mar 2019 8:44pm
excossack
Thanks lightening. A bit more research required. 1999 Defender TD5 110
Regards
John M0VAZ
Post #763411 14th Mar 2019 2:14pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
It should be an NNN ecu and not an MSB ecu. The defender has migrated, leaving the owner behind.
Post #763767 16th Mar 2019 12:08pm
lightning
The cruise control has transformed long journeys in my 110. We recently drove to Scotland (a round trip of 860 miles) and it was great to set the speed at 65mph and then just steer. After slowing down you can just press the resume button.
I would say it’s the best accessory l have fitted.
Post #787473 18th Aug 2019 2:40pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
FWIW... I have an 2000 MY and would love cruise as well but alas.... Its not cruise but this little mod made long distance driving a tad more comfortable by undoing one of the throttle springs. Its easier on the right leg.
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #787487 18th Aug 2019 3:41pm
lightning
I have modified mine as well, by drilling a new hole for the spring a bit further round, so reducing the tension.
Post #787491 18th Aug 2019 4:24pm
lightning
Post #787492 18th Aug 2019 4:38pm
4RF RDS
[quote="lightning"]I have modified mine as well, by drilling a new hole for the spring a bit further round, so reducing the tension.
Laughing that’s how I started then I just realized it was two separate springs. So I decided to save myself the drilling 👍🏻 Its a good mod regardless 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #787556 19th Aug 2019 1:40am
Bim
United Kingdom 2005 Defender 110 2.5 TD XS CSW Tonga Green
Would like to do the cc mod but will it work with Roamer overdrive also if using a speed healer is this switched on and off with the cruise control
Post #881639 28th Jan 2021 10:06pm
TheLastMaverick
United Kingdom 2001 Defender 110 Td5 HT Caledonian Blue
It should work with the overdrive with the speed healer fitted, overdrive only normally affects CC in 5th gear, but the speed healer will allow full use of CC.
The CC should not interfere with the workings of the speed healer.
Mike
Post #881662 29th Jan 2021 12:41am
Page 4 of 5 <12345>
