Home > My Defender > An Anoraks Utility Station Wagon
Page 15 of 31 <123 ... 141516 ... 293031>
donmacn
Quote: "Interestingly, they're chamfered on one edge, so are effectively handed and have to be fitted the right way around."
I'm assuming that chamfer is on the leading edge? I'd guess that's intended to further reduce the risk of brake squeal? Donald
(The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html)
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #761691 3rd Mar 2019 1:46pm
landy andy
I’m surprised it failed on those pads not just an advisory, unless the others are worse.
Post #761693 3rd Mar 2019 1:57pm
No, the fronts are fine. This was, by far, the most thorough MOT that I've put a car through, though. I used a Council-run facility and everything was absolutely by the book.
They also had a very neat ramp that had the ability to rock both the steering and the complete vehicle whilst the tester inspected the steering and suspension, which was something I hadn't seen before. Darren
2013 Defender 110 USW XS
2013 Discovery 4 XS
MY 110 USW BUILD THREAD - MY 200tdi 90 BUILD THREAD - Instagram: @landroveranorak
Post #761696 3rd Mar 2019 2:23pm
Procta
You want to see the shopping list the mot tester gave me on both of my cars, The 306s were that daft I had to pull him about. Needless to say its not going back there again, or the replacement car Thumbs Up They did really milk the defenders retest on such a small items. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #761798 4th Mar 2019 6:56am
Just to be clear, I'm not complaining about a thorough MOT. In an ideal world, they should all be like that. Darren
2013 Discovery 4 XS
Post #761809 4th Mar 2019 8:56am
Yay.
 Darren
2013 Discovery 4 XS
Post #761937 4th Mar 2019 9:59pm
Procta
for me its the daft things, if you had seen the advisories he had put on the defender, and the 306 you had to laugh at!!
he nearly brought down the value of my defender with the insurance claim! If someone hadnt have had a car advertised on EBay for 8k that was older and higher mileage i wouldnt have got my 8. yeah make sure the motor is safe and road worthy but daft advisories need to be questioned. Rolling Eyes Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #762078 5th Mar 2019 8:41pm
L110CDL
Yay.
Nice pic LRA Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #762246 6th Mar 2019 10:40pm
Steering Guard
With the weather dry and relatively warm, and a bit of spare time, today I've fitted a steering guard. It's a three piece steel galvanised affair as supplied by First Four Off Road, although I bought it from VVS210 of this parish. It's a substantial bit of kit - 10mm thick brackets and 6mm thick guard plate - and so when I collected it from him at Newbury it was 'kin heavy to carry back to the car park!
Whilst it has a galv. finish, I didn't want to leave it like that and so have spent a bit of time over the last week cleaning, priming and spraying it. The chassis brackets are now black with yellow highlighted towing eyes, and the guard plate has been coated with grey enamel.
Fitting was relatively straightforward apart from the weight! The chassis brackets bolted on easily enough using the bolts for the original lashing eyes at the front (which have very nice captive washer nyloc nuts) and one of the steering box bolts on the drivers side along with a new M8 bolt on the passenger side at the rear.
Because of the vagaries of Land Rover chassis tolerances, it was necessary to leave the chassis bracket bolts loose and attach the guard plate before tightening everything up, as otherwise the holes wouldn't line up. Fiddly but not the end of the world.
All mating surfaces and bolt tubes were given a squirt of Dinitrol before assembly and I also fashioned some dense rubber pads to fit between the brackets and guard plate. It's difficult to know how much difference the latter will make but it was easy enough to do and might help with NVH as the guard makes the front end extremely rigid.
And here's the end result, which I'm very pleased with:
 Darren
2013 Discovery 4 XS
Post #768663 15th Apr 2019 12:40pm
VVS210
Rolling with laughter Rolling with laughter Rolling with laughter
I did warn you it was heavy Whistle
Looking good and glad to see it going to a good home
Post #768669 15th Apr 2019 1:34pm
Yeah, I regretted not bringing the sack truck that my wife had suggested within 50 yards of your pitch Laughing Darren
2013 Discovery 4 XS
Post #768672 15th Apr 2019 1:58pm
DefenderJon
Northern Ireland 2000 Defender 90 Td5 CSW Epsom Green
Oops, wrong thread.
Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!!
Post #768837 16th Apr 2019 5:15pm
VVS210
And I bet she won't let you forget either... Laughing
Post #768863 16th Apr 2019 7:26pm
DefenderJon wrote:
Fitted new felts to my sliding rear windows. Nice easy job and windows are now completely rattle free. Haven’t driven it yet, but would imagine it should be quieter and hopefully warmer!
Wish I’d done it years ago. 🙂
Part no. CZL000020 (OEM)
Jon.
I'm guessing you meant to post this in a different thread, Jon. Darren
2013 Discovery 4 XS
Post #768887 16th Apr 2019 9:38pm
Had a rather unplanned expensive day, today. Took my Defender to Challenger 4x4 for an oil change and to investigate a clonk somewhere at the rear end and ended up with a new Ashcroft output shaft Shocked Still, it drives very nicely now Rolling Eyes Darren
2013 Discovery 4 XS
Post #768888 16th Apr 2019 9:54pm
Site Copyright © 2006-2020 Futuranet Ltd & Martin Lewis
