Home > Technical > R380 TD5 clutch, Issue, Failure or designed that way?
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Just noticed something odd with my clutch/ Gearbox. Not sure if its because i'm using it more often or Whether something has actually changed.
So when i change down gears the stick will prevent me changing down unless my revs get down to an appropriate level. there are three large Hills where i live and i Often use engine breaking for obvious reasons.
is this a safety mechanism? has this always been the case?
Is my clutch or gearbox having an issue? do i need a new clutch? (Clutch weight and height is fine)
Thoughts chaps? I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #761531 2nd Mar 2019 3:33pm
rallysteve
Sounds like the synchros might be work out to me if your clutch is working fine 02' 110 TD5 Double Cab Rebuild Thread
Post #761534 2nd Mar 2019 3:41pm
Double-declutch.
Post #761557 2nd Mar 2019 7:04pm
OsloBlue
I did try a double de clutch, seems to only want to work 30% of the time. I'm on IG: https://www.instagram.com/osloblue42/
Post #761567 2nd Mar 2019 8:30pm
landy andy
Start by changing the oil.
Post #761596 2nd Mar 2019 9:58pm
On the assumption that you're double-declutching correctly that does suggest a gearbox fault. Even if the synchro has become completely ineffective you should be able to change gear smoothly and silently.
Post #761613 2nd Mar 2019 11:39pm
grafty99
Could be a snapped or damaged bias spring...... 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #761615 2nd Mar 2019 11:46pm
