Home > My Defender > My 110 MILLIE. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10530 |
Millie has got a bit of bling on her now
I thought that she deserved it and this package came for her about 4-5 weeks ago Click image to enlarge so unwrapped it a bit more ..... Click image to enlarge Then lifted up the lid .... Click image to enlarge To find this .... Click image to enlarge So i finally got time to put it on Millie, but it would not fit so i had a good look and it would not fit over the outer ring, in needed to be another 5 mil wider so i went indoors and got on the phone to Optimill and explained the problem, so they said send it back and we will do another one for you, so on Monday i had the package come for me and i unwrapped it again and guess what, it fits........................................ Yes i know it is dirty there, i'm not washing her off until after this coming Sunday Click image to enlarge I'm well chuffed now and my hat goes of to Optimill as it was no trouble at all to sort the problem out 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
10th Apr 2019 8:28pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4789 |
Top quality stuff from Optimill and great service too Clayton. 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
10th Apr 2019 8:56pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19610 |
Looks good! Donβt leave it behind though! Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§
10th Apr 2019 9:22pm |
You can't, the keys don't come out until it's in the locked position when fitted 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
10th Apr 2019 9:29pm |
Yes as always Simon i have been waiting for a long time for them to make one for a Tdi model 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
10th Apr 2019 9:30pm |
Well that's even better then. Doubt you'd have it hangin off the ignition without noticing. Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§
10th Apr 2019 9:31pm |
Clayton. |
10th Apr 2019 9:57pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4942 |
I think MILLIE may look good with the stainless steel vents and grill and surrounds from BeaTie Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
16th Apr 2019 5:53pm |
G4V JW Member Since: 24 Sep 2018 Location: Northants Posts: 190 |
Bloody good innings that, well in Instagram; @gavin_walding |
17th May 2019 8:38am |
I am toying with the idea of the idea of the fuel cap for mine, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
18th May 2019 10:39pm |
As yours is a Td5, then go for it 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
20th May 2019 9:58pm |
As i got in Millie to go to work this morning, yes i know what day it is
i noticed this .................... Click image to enlarge So an update for you all.................... As she was going in last Wednesday for another one of her 6,000 mile services, 2 or 3 days before she started making a nasty noise and i was thinking that it was the front diff saying, i have had enough now So i left work a bit earlier than normal and i went over to my indy to ask them what they thought, so they did a few tests and thought that it could be the front diff, but 100% sure it was As he was checking all underneath with the prop shafts, he noticed the back prop shaft that attaches to the diff was a bit loose and the seal was slightly leaking oil, so he took it off to have a further look and found that the nut that attaches the adaptor to the shaft was not tight at all and could undo it with his fingers, so as Millie was going in he did not want to put any lock thread on it and it will be all sorted out Well on my way home the nasty noise had gone and when i got home i rang them to tell them and no need to talk about replacing the diff Then on my way to work the nasty noise started again and luckily i was dropping off Millie for the service work to be carried out and they could sort out this nut problem. So after they had done the work, my indy told me that he had to put more than usual thread lock on as they can't get a new nut from LR as they don't make it anymore So all is good at the moment and i was told that if the nasty noise comes back i have to go to my indy sooner rather than later The question is, does anyone out there in this fab parish know where i can get one of these special nuts for my Salisbury axle Thank you for any info on this 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
27th May 2019 8:27pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10363 |
2 X Porsche.
27th May 2019 9:14pm |
If only 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
27th May 2019 9:16pm |
