Home > My Defender > Grafty's Td5 90
Page 84 of 124 <123 ... 838485 ... 122123124>
grafty99
Also forgot to mention the latest mpg figures. The most recent tank was 32mpg - not too bad considering that included the Wrynose and Hardknott pass and driving through the lake district Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #760279 23rd Feb 2019 1:25am
grafty99
Back home now, what a fantastic trip. I'd recommend it to anyone, stunning scenery and roads.
The stats:
2288 miles
29.46 MPG average
42 MPH average speed
353.04 L of fuel
If you get a week (preferably more) going spare, do the NC500! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #760556 24th Feb 2019 1:53pm
Co1
That MPG is mighty impressive. I’m getting just under 30 for “normal” driving having had a BAS remap. Have you done anything specific to get better fuel economy?
Awesome pics by the way, what camera set up are you using?
Oh, and I’m 40 in a couple of years and my birthday treat will be the NC500 and a MacNab attempt on the way home!
Post #760569 24th Feb 2019 4:40pm
grafty99
Thank you, nothing specific really.
Gentle driving and good diesel. I also use either 2 stroke oil or miller's diesel ecomax.
Mine has road biased tyres which will help slightly. 1.2 transfer box and discovery V8 5th gear in the gearbox.
Engine wise it has a VGT, full size intercooler and 110mm air box feed. Remap by IRB developments. Very minimal smoke (a very slight haze under full load)
Best MPG on the trip was 32 MPG but generally I get about 30 with normal driving.
Camera is mainly just my phone, Huawei P20 Pro. The odd telephoto shot with a Nikon D3400.
NC500 and MacNab in one holiday! That'll be one to remember! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #760583 24th Feb 2019 5:55pm
Co1
Cheers Grafty.
Post #760585 24th Feb 2019 6:12pm
grafty99
Thumbs Up
Thank you to Blackwolf for lending me his trailer today, I bought another project (because can you ever have enough? Rolling with laughter)
1990 Vogue SE
Post #760591 24th Feb 2019 6:38pm
Procta
ah I read about the 2 stroke thing on pug 306.net years ago for the common rail diesel engine. I never tried it though in case I Censored the injectors. That's good mpg, mind grafty. my 300 wasn't anywhere near as good as that, not matter how good I drove it. started to get better after I sorted the fuel problems and I suspect the timing was out too. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #760645 25th Feb 2019 6:58am
grafty99
Well I've been using 2 stroke oil for the last 70,000 miles without any injector problems, you only put a small amount in (300ml on a 60L tank)
Taller gearing makes quite a lot of difference as it's not revving as high at cruising speed. 60MPH is just a shade under 2,000 RPM on mine.
Timing can make a big difference to fuel economy of its out. If the timing is retarded it won't burn all the fuel you inject and so is less efficient Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #760651 25th Feb 2019 8:32am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
With timing on a 300/200tdi I can see that the 'boost ring' from Fourby would be a good modification as it advances the timing at high revs.
32mpg is mighty good though and that V8 5th gear is a brilliant idea. I this possible on a LT77 I wonder.
Post #760655 25th Feb 2019 9:24am
grafty99
I'm not sure if that can be done to the LT77. It might be worth getting in touch with Ashcroft transmissions Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #760697 25th Feb 2019 2:32pm
L110CDL
Good stats there grafty Thumbs Up
Whats MacNab Question 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #760784 25th Feb 2019 11:14pm
grafty99 wrote:
Thumbs Up
You're welcome! Evidently you got it loaded ok, hopefully unloaded without difficulty?
Post #760785 25th Feb 2019 11:18pm
grafty99
Yes loaded OK, getting it off was fine too. It was tight though! Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #760812 26th Feb 2019 9:11am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
How do stranger.....did the NC500 in July of last year.....but in the VW transporters...…….Brilliant adventure and be going back to do more Putting Dreams on Drives at JLR Solihull..
Post #761746 3rd Mar 2019 7:26pm
Procta
MacNab is Scottish tea, made with the juices of freshly squashed haggis, and its proper bernie clifton Shocked Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #761902 4th Mar 2019 7:17pm
