Home > Puma (Tdci) > Suspension Bushes
zephyr4
Suspension Bushes
Looking for advise where to get a front and rear suspension kit I don't need any thing fancy she only gets used for normal road use, I have seen a kit on the Bearmach site.
2007 90 StationWagon 2.4TDCi
Thanks for any help z4
Post #759972 21st Feb 2019 12:04pm
MK
In the web look for landrover wokshop manual. You get to see all necessary parts Puma 110" SW
Post #759988 21st Feb 2019 2:19pm
excossack
I have just done my bushes front/rear and went for genuine items from Dan @ Duckworths. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #759998 21st Feb 2019 4:17pm
zephyr4
Just done a search on Duckworths I cant find them.
z4
Post #760024 21st Feb 2019 7:14pm
excossack
Give Dan a buzz and have a chat about, easiest way 1999 Defender TD5 110
Regards
John M0VAZ
Post #760042 21st Feb 2019 8:31pm
zephyr4
Ok thanks, if you don't mind can you tell me the price.
z4
Post #760057 21st Feb 2019 9:42pm
excossack
Off the top of my head not sure on price but I think it was less than or equal to some polybush kits, but the list of bushes is as follows;
Front radius arms
2 x bushes per arm at axle (4 total) (24mm)
2 x chassis end bushes per arm (4 total)
2 x bolts + 2 x nuts for axle end bushes
2 x nuts for chassis end (30mm)
2 x panhard rod bushes
2 x panhard rod bolts + 2 x nuts
Rear arms
2 x axle end bushes + 2 x bolts + 2 x nuts (24mm nuts)
2 x chassis end nuts (30mm nuts)
4 x chassis end bushes (bought elsewhere) 1999 Defender TD5 110
Regards
John M0VAZ
Post #760070 21st Feb 2019 10:26pm
zephyr4
Thanks for the update.
z4
Post #760123 22nd Feb 2019 9:16am
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Looking at this subject at the moment too.
Did you fit the new genuine LR ones yourself? Did you have a press or a vice and big hammer?
I'm only considering polybushes as I hear they are easier to home fit than genuine, but if genuine is do-able at home they'd be a better bet. Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #760126 22nd Feb 2019 9:34am
excossack
I got myself a 2nd hand 10t press which did the job. Yes you can use hack saws to cut out the old bushes which I did consider before getting the press and I did at one point start cutting into the metal sleeve of the bush to try and get it out until I found a suitable form to go into the hole in the arm to press the bush out. (I think it was a 1" socket) I suspect with a big vice on a decent bench you can insert new ones.
route I considered was to get a spare set of arms and fit bushes to these and swap over. I only did this with the rear arms as I got a set for a good price. 1999 Defender TD5 110
Regards
John M0VAZ
Post #760143 22nd Feb 2019 11:28am
