Home > Maintenance & Modifications > Puma rear door lock on a 300di?
lb73
Wales
As I’m in the process of repairing the rear door on my 99 110 300tdi csw, I want to convert the reardoor lock over to central locking as i’ve already done the other four doors. Thinking of fitting a puma door lock to allow me to attach a solenoid. So before I buy one should it be a straightforward swap ? Thanks in advance. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2002 Dax Rush 3.9 V8
2012 Audi A3 tdi
2020 Renault Kangoo electric
Post #759308 17th Feb 2019 10:49pm
grafty99
You'll need the rocker pivot and remote push rod to mount the actuator out of the way.
The rod comes out of the top of a puma handle mechanism.
Also you'll probably want to fit a mudstuff door card or similar to make more room Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #759314 17th Feb 2019 11:08pm
Whilst I appreciate that the whole point of central locking is to ignore this sort of thing, bear in mind that it'll be a completely different key. The barrel is larger to accommodate the later keys, so you'll need the matching thinner plastic bezel to fit the hole in the door.
I did the reverse of this to my old 90, fitting an earlier lock to a Puma rear door and apart from having to swap the bezel on the door I'd bought, it bolted straight on. Darren
Post #759317 17th Feb 2019 11:17pm
lb73
Wales
Thanks both for the info Thumbs Up will put the mud door car on the list as well 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #759320 17th Feb 2019 11:33pm
