Home > Tdi > Drive or not?
Huttopia
Drive or not?
Oil leaking from the top pipe into the intercooler- enough to make a decent mess running down the outside of the intercooler.
I appreciate it’s difficult without pics but should I drive it or not?
Huttopia
Post #759286 17th Feb 2019 9:45pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Assuming it's a 300tdi with oil cooler in the radiator I used to get a leak from the union from time to time. Tightening (carefully) the union usually solved the problem.
Minor oil leaks are not too much of a problem on the tdi, in fact they help keep the chassis rust free Very Happy
Post #759290 17th Feb 2019 9:55pm
Huttopia
Yes a 300tdi- it’s the pipe at the bottom left of this picture (you can’t actually see the joint in the pic)
Post #759292 17th Feb 2019 10:03pm
Retroanaconda
Regardless of whether there is excessive oil in the inlet tract, it shouldn’t leak from where the hose goes onto the intercooler. You have a leak there that will also be leaking air under boost. Check/replace the Jubilee clip.
Tdi engines often have quite a lot of oil in the intake. I would suggest that so long as you are not loosing enough oil to be noticeable on the dipstick over say 100 miles then it’s probably not worth worrying about.
Post #759298 17th Feb 2019 10:12pm
Huttopia
Thanks. I tightened the jubilee clip and checked the engine oil, which was fine. I suspect the turbo is on the way out.
Post #759300 17th Feb 2019 10:16pm
Retroanaconda
That’s possible, but unlikely. Tdi turbos are very robust.
Far more likely and worth checking is the cyclone breather being blocked up and passing oil into the intake system. To test this, clean out all the pipes and intercooler etc. and then divert the pipe from the breather into a catch can secure somewhere. Block off the inlet pipe stub and go for a decent drive. If the oil is still appearing then the turbo is passing it and needs replacing. If not then the breather is at fault.
Post #759302 17th Feb 2019 10:22pm
L110CDL
Sorry to divert from the op question, but what is that unit with the belt on, just below the header tank in the pic please Question 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #760256 22nd Feb 2019 10:58pm
csw110
Aircon compressor.
Post #760258 22nd Feb 2019 11:05pm
Procta
I would give the cyclone a clean out or just replace it, Me and my dad replaced ours with Ali sport units. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #760383 23rd Feb 2019 6:12pm
L110CDL
csw110 wrote:
Aircon compressor.
Thought it was, just making sure, many thanks Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #760794 25th Feb 2019 11:50pm
oneten110
The intercooler should be flushed every 50,000 miles. Land Rover used to sell acetone for this purpose. Similarly the cyclone should be flushed or rinsed out frequently. It is not a Defender, it is a One_Ten
Post #760805 26th Feb 2019 8:32am
Huttopia
Ok, so the turbo is on its way out. I don’t know if it is most cost effective to send it off for repair / exchange / get a new one. Any recommendations?
Thanks
Huttopia
Post #762867 11th Mar 2019 9:35am
L110CDL
Depends if you have a budget to stick to, if not, when Millie's turbo finally goes, i will be putting a vnt in Very Happy 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #762934 11th Mar 2019 9:29pm
Huttopia
I don’t want to spend any cash I don’t have to on it, and I’d like to keep it as original as possible!
Post #762940 11th Mar 2019 9:55pm
L110CDL
ok, no worries Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #762941 11th Mar 2019 10:04pm
