Home > Maintenance & Modifications > Gull Wing Windows
Page 3 of 5 <12345>
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Post #738555 4th Nov 2018 2:30pm
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Thanks, sourced Thumbs Up
Post #738994 6th Nov 2018 11:46am
dantastic
Ok, I have a pair of Front Runner gullwing windows sitting on the floor here. I have ordered stainless bolts and I need to get hold of some black silicone sealant. This is an area I'm unfamiliar with. What do you get? Just black silicone in B&Q or...?
Post #759089 16th Feb 2019 9:48pm
landy andy
DON’T USE SILICONE.
I would use a black Pu sealer. The best is Tiger seal.
Post #759090 16th Feb 2019 9:51pm
2010Blackdefender90
I put a thin bead around the outer edges of the holes on the frame on the top and side edges, keep the water out
Post #759106 16th Feb 2019 11:19pm
dantastic
landy andy wrote:
DON’T USE SILICONE.
Hahahaha, perfect! I'll get some Tiger seal! Thanks!
Post #759147 17th Feb 2019 9:57am
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Reviving this thread. I'm currently making my own and i need some help.
Can anyone tell me what the preset force are on those gas struts. 50N, 100N or 150N?
I could only get 150N struts and I'm not sure if the 6mm toughened glass will hold up to them.
Post #845915 25th Jul 2020 12:54pm
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
There you go....Frontrunner glass. 150nm.
Post #845919 25th Jul 2020 1:07pm
jfh
Thank you very much, this helps a lot. This is the last leg of this project and the glass isn't cheap.
Have a great day.
Post #845922 25th Jul 2020 1:22pm
Timcat
No problem Very Happy
Post #845924 25th Jul 2020 1:34pm
Co1
Have a great day.
Looking forward to seeing this. Make sure you update this thread once complete. Thumbs Up
Post #845974 25th Jul 2020 6:32pm
jfh
Thanks. I will try to update as I go along.
This is a project that I wanted to do for so long, unfortunately money is always an issue.
So it's slow going, but the end is insight.
I first made the door out of aluminium to make sure that I get it right before the glass is cut. That's was a good decision as the locks in the photo are are about 25mm too low. Embarassed
The aluminium is a bit soft so it bends al little where the gas struts connects to the door. That's the main purpose of me asking about the gas struts. The toughened glass will be much harder and less likely to flex but I still have to commit before I know.
I'm doing this all out of my head/ reverse engineering with a bit of help from fellow forum members. (This forum and the SA 4x4 community forum)
Post #845981 25th Jul 2020 6:54pm
jfh
Just an update, things are going slow but getting there.
Just finished painting and did a quick mock-up.
Installation will be next weekend, if all goes well, it'll be a long weekend for us in SA
As I'm eventually going for glass doors, I've opted to first test the setup with a aluminium door.
Post #856022 14th Sep 2020 4:55pm
Zed
Looking good. Nice work mate. WARNING.
Post #856030 14th Sep 2020 5:50pm
jfh
Thank you.
Post #856041 14th Sep 2020 6:36pm
Page 3 of 5 <12345>
