![]() | Home > Technical > Propshaft fitment |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8407 ![]() ![]() ![]() |
It depends what length the front prop goes to on full bump. If it's less than 635 then prop is too long. If your std height it's prob ok. Rear prop only has 15mm movement from full bump to droop on a 90 with a 2" lift. Cheers
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 841 ![]() ![]() |
Standard height. Out of interest when the propshaft is fitted in the "normal" road going position how far extended should it be from fully closed ? I presume when the suspension compresses the propshaft will also compress (get shorter), is that how it works? BORG - Bucks & Oxon 4x4 Response Group
yep it compresses when the axle goes up. total movement on a rear vehicle with a lift and dislocation suspension on my 90 (+5" shocks) was 15mm.
so if yours sits at 640 front normal i doubt it compress 5mm on full bump there fore the prop you have that compresses to 635 should be ok. not ideal though. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
