110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Party Monkey, where do you mount your trailer socket? If not already there I can recommend in the rear X member recess - it goes a long way to keeping it safe and cr@p free.
PMonkey mine was really rusty inside where you plug the trailer plug in.... when i braked my headlights use to come on ? as said the grease has worked.... when K9F did mine he looked at his and it was the same rusty inside and he never uses it.... now you have greased your's up it should be fine
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
Just on a side bracket on the drop plate, which was how I inherited it. Good shout on the cross member recess - will take a look at that ![]() @fekete.... yep all should be good now ![]() Thanks all.... Jon - 110 td5 [sold]. Currently Defenderless. |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 ![]() ![]() ![]() |
Cleaned Cleaned and Cleaned and then Cleaned some more !
![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Very nice CR
![]() Put a load of bungs in the chassis side holes leaving the bottom ones clear to drain water. Still have to seal the gaping holes ![]() ![]() ![]() ![]() Used more Dinitrol and also bought some ACF-50 on BigMikes recommendation and have used it in the engine bay on the electrics and rusting common rail, looks to be good stuff, and easy to use especially with the extension nozzle! I have put it also on the badly rusting Series2 rear cross-member for the ultimate test to see how it copes. I was going to buy some of the Dielectric grease but can't be bothered disconnecting everything to treat it all and this ACF-50 along with the Wurth Anti-Corrosion wax I have plastered everything with should do the job. ![]() ![]() Can be got through E-bay from Wemoto.com £12.45 delivered (a lot cheaper than the £16 for the Wurth stuff!) ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 ![]() ![]() ![]() |
Wow!! ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
What will you do if it ever rusts. Word of advice...keep the front dumb irons open DO NOT seal them. If you really want ill sell you the proper rubber inserts (choose your age) as the first thing I do is remove them - waxoyl and leave open. The number of defenders that have had them covered - the crap still gets in, the rots it - even if you waxoyl it. Oh and incidentally the hole is a pillar jack point ![]() |
alanhid Member Since: 24 Jan 2010 Location: South Lanarkshire Scotland Posts: 221 ![]() ![]() ![]() |
Fixed mine
![]() Def 90td5 CSW xs 2006 |
Went to scotland to pick up some bits for my landcruiser
![]() lovely drive though, fantastic |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Well it is God's Country ![]() ![]() |
"proper rubber inserts" MSE, Thanks for that, good to know they produced them. Saves on more time fabricating things! I have even ordered the Entreq mudflap reinforcement brackets - how lazy is that!
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
Fitted aerial mount for CB on rear left light guard. Also fitted an earth wire. It's been 20 years since I last had a cb, but this time I went for a handheld model, so I can easily transfer it to my 2a (no roof, so no need for external aerial).
Handheld actually worked quite well inside the 90 with the rubber duck fitted, but I came across my old mirror/bike aerial mount, so I thought, what the hell. Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
Cin - who are you CBing?! Defender 110XS SW gone... now VW California 180 4 Motion.
Anyone within range I suppose, but really it's just for inter vehicle communication on runs out green laning and such.
