![]() | Home > Td5 > Oil depression control valve removal question |
| AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 149
Hi all, I would like to change my oil depression control valve LLN100140L. Has anyone any tips for removing the bottom part from the turbo hose. It appears to be permanently fixed with some sort of hose collar clamp. Is there a tool for removing this clamp and is there an easier way to fix the replacement ? Cheers Andy
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6054
There are special tools to remove and refit. Not overly costly.
Thanks both, after more googling I think it maybe a clic r clip, looks easy enough with the right set of pliers
Yes that’s the ones
| Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310
Can I ask what has led to it needing to be replaced? Symptoms?
Patrick |
| bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239
Ping it off with a screwdriver. Replace with a jubilee clip
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
You can clip them back together with a pair of end cutters if you're careful when you remove them
I haven't got any symptoms as such leading me to change this unit. However the surrounding area is covered in old oil and grime and I've read that some consider this bit of plastic which is subjected to hot gasses should be a service item. So I'm going to pop it off and have a look. |
Thanks!
Will be watching with interest. Patrick |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3529
I changed mine for the same reason. “We don’t sell many of these” said the LR parts guy.
It made no difference but won’t do any harm to change it. I cut off the clip and replaced it with a plastic one. |
| All times are GMT |
