![]() | Home > My Defender > here she is |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 ![]() ![]() |
Cool , I can get a galvanised cradle brand new for 70 quid , will remove the two uprights that my piece of wood is on and mount the cradle as low as poss , but high enough so the a frame but don’t hit it and the exhaust may get a cut and re-route too
Weston18 Member Since: 20 Oct 2013 Location: Norhamptonshire Posts: 100 ![]() ![]() ![]() |
Nice to see something different. Keep it up.
Thank you
![]() A little update , i’ve bashed my original cradle fairly flat and positioned in the back , and it works very well indeed , i’ll Still cut out the little uprights and put the cradle down onto the chassis , i’ll weld nuts into the chassis towards the rear and make a bracket at the front to hold to the bulkhead . Will but n bolt it for ease of removal , the pipes sit well on the back on the tank , 4 easy cuts , spin the connector 180 and plug in . Will use a short piece of rubber to join , will rachette the tank to the cradle . May even get a new cradle one day ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11026 ![]() ![]() |
Don't forget to put some red paint on it ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
No red paint left i’m afraid , so a quick coating of yellow n silver
![]() ![]() Click image to enlarge ![]() Click image to enlarge |
That looks much better
![]() Has your daughter thought of a name yet ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
No name as yet , but the cradle has a proper coat of paint now
![]() ![]() Click image to enlarge |
I prefer the red paint
Red paint has been ordered
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
So today I popped out to test the new tank position and pipe work , the defender minus roof too , it was superb weather , well the tank was ok , but the bulkhead split , turns out a previous owner had repaired with fibreglass filler , a quick patch done , repair panels another day , also noticed a dry bearing noise , the viscous fan housing fan is rather shot , and just to top it off , the steering pump has sprung a leak , more jobs after tomorrow’s pit run
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
A superb pit morning , except the lake was a smidge deep and upon filling the cab , I
![]() ![]() ![]() Click image to enlarge |
I like your version of the " sun roof " off
![]() Great you got her going again and had a great day ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Hello fella , how is ya ? I grabbed a couple of screens shots from someone’s lake crossing video , you can hear my viscous bearing from quite a distance
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 728 ![]() ![]() |
Watch out for the crocs
![]() That is beyond deep ![]() |
