![]() | Home > Puma (Tdci) > Broken spline in axle housing |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6346
pretty sure mine didn't have a gasket and there's been no sign of a leak. Obviously the faces had a real good clean up before hand.
| Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647
Thanks Caterham , I’ll give them a clean and use sealant
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986
Just sealant required
| andrewlandy Member Since: 07 Feb 2016 Location: Graz Posts: 82
Why would a diff go like this?
| windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311
would be good to see how 'slotted' the center carrier is.
I bought an entire axle from a dismantler as I needed a new axle housing after mine snapped on a weld (another story). This is the replacement and it came as an entire axle. As mine had high mileage and this was a supposed low mileage donor I thought it made sense to swap them over like for like.
Clearly that was an error and on hindsight I should have just purchased a new housing but was watching the pennies. Lesson learnt . No idea what caused this but the steering began wanting to self center quite purposefully as if the diff lock was engaged. The next thing I know there’s a crunching noise whilst doing a three point turn , followed by loss of drive. It wasn’t very dramatic to be honest but I’m glad I wasn’t out in the sticks . The damage to the diff is horrific but it doesn’t appear to have done anything to the half shafts . I’ve been cleaning out all of the fragments from the casing all afternoon! |
That was an interesting read Blackwolf. You now make me think I should have upgraded to a 4 pin front diff . I did notice they were quite a bit more expensive, presumably because they’re rarer ?
I managed to get the recon diff back in this afternoon, a bit of a struggle when lying on your back but not impossible. Hopefully have it all finished by tomorrow! |
I’m not sure which component the center carrier is but I can take a pic for you |
The center carrier becomes slotted where you see the shiny shaft sticking out on the photo. The photo shows the how my pin broke in my 2011 Tdci, this was due to the holes at either end becoming elongated.
I swapped before major failure by check diff through oil filler hole. Click image to enlarge |
Yes the holes are hugely elongated where the shaft sat . I’ll take some close ups tomorrow
Yep that’s the norm, and shows the weak point
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
I am told (by an LR tech I completely trust and believe) that LR no longer supply 2-gear diffs as replacements for LWB Pumas. The fours cost more because they're much stronger and are, as you say, both scarcer and more sought-after.
When my front diff did what yours did I found that it was significantly cheaper to buy outright a new built-up Ashcroft diff with ATB and HD ring and pinion than to buy an exchange (recon) 4-gear diff from LR, so that's what I did. It's worth bearing in mind that that single puny cross-pin is the only thing transmitting power to the halfshafts. So your engine torque, multiplied by the reduction gearing in both boxes is divided equally front and rear by the centre diff, multiplied again by the reduction gearing in the diff, and shoved into that little pin. No wonder they fail! |
I just wanted to conclude this thread.
Diff is now changed and has eliminated all of the issues I was experiencing before it failed , no more torque steer, no more dragging to the left and vague steering. Interestingly when I spoke to Ashcroft transmissions a couple of weeks ago the chap I spoke to said that an open diff on its way out wouldn’t cause the above symptoms! So it does go to show that even the experts get it wrong . So now I have a defender that drives well again after months of issues , that along with the satisfaction of doing it all myself having lost all faith in our local mechanics has left me considerably more knowledgeable about my defender and a with big grin on my face !! Thank you to all who contributed Now just to sort the blue smoke on start and overrun when cold !! Turbo I feel https://www.instagram.com/hustynminepark/ |
Perhaps he was only there to refill the water-cooler! |
