Home > Puma (Tdci) > Broken spline in axle housing |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
Morning all
I overhauled the swivel and hub over the weekend . On removing the swivel I found this little bit of metallic debris sitting just inside the housing . It clearly looks like a tooth from one of the components but is approximately 3-4 times the size of a half shaft spline . Any ideas on what it exactly ?! The defender is pulling vaguely to the left and suffering from light torque steer , could this be the cause ? All bearings and swivel pins are good , suspension set up is only a few weeks old. A bit of slop in diff (1/4 of a turn) and a tad clunky. Other than that no awful grinding noises. I’m falling out of love with this particular defender ! Thanks Rich Click image to enlarge |
7th Jan 2019 10:07am |
Should add that it stops pulling left when you dump the clutch
7th Jan 2019 10:09am |
Thank you Blackwolf for your in depth reply .
Yes it was inside the axle tube itself , just sitting on the edge with half a dozen much smaller fragments (1mm ish ) ! Ironically this front diff was an entire axle replacement from a used 2012 110 so I imagine that would be the stronger 4 pin you speak of ?! I have my original diff in the broken axle housing so I could swap that over or I suppose or buy a reconditioned unit from Ashcroft or the like. Out of interest who do you use in the west country for your work or do you do most of it yourself ? |
7th Jan 2019 12:05pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16931 |
I do my own work, sadly I don't trust anyone else to do it (at least not anyone I can afford)!
You should certainly be able to tell if you have the two gear or four gear diff by peering through the filler hole, they are very different in appearance. The two gear diff has a very open carrier (as in my photos) whilst the four gear is solid. If you can see the differential gears (I don't mean the crownwheel, of course) then it is a two gear diff. I can think of no circumstances under which I would now fit a two gear diff in the front of any Defender, four is the way to go. If you old 2-gear diff is OK and you need a new one for your current axle, I would suggest either fitting the old one temporarily and using the broken one as the basis for an Ashcroft build (this presupposes that the broken one isn't so damaged that it can't be used) or use the old good one as the basis for an Ashcroft build. When I changed mine, the cost of a fully-built Ashcroft ATB diff assembly bought outright was very much less that the cost of an exchange standard diff from Landrover. it might as a fist step be worth draining the axle oil to see how much additional debris comes out, but the presence of any fragments at all in the axle tube is bad news. |
7th Jan 2019 12:18pm |
Thank you Blackwolf I believe you talk sense ! I’ll drain it and let you know what I find but at the moment it doesn’t feel at all safe to drive , unpredictable steering isn’t at all ideal .
Will let you know how I get on |
7th Jan 2019 1:14pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 581 |
It looks like a broken tooth from diff gear wheel - the smallest one. Las summer I was replacing both diffs on our Discovery 2 for lockers and both were nearly shot - in rear there were small chips on some wheels, front had tiny beak lines on all teeth and some metalic-like oil inside. it took me quite a long time to clean the axle tubes from small metal particles - first wiping then, than picking up the rest with strong magnet. If you don't have the oil drain plug with magnet, get one. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
7th Jan 2019 6:35pm |
Thank you madtom, i’ll definitely be cleaning out the axle casing .
Interestling I had to drive it locally this evening , up a very long steep hill , with my foot down on the accelerator the steering was really quite stiff until I eased off the accelerator at the top ! Diff out tomorrow |
7th Jan 2019 6:48pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3616 |
what Blackwolf said diff probably on the way out, take a look at the Ashcroft ATB thread. DEFENDER 90 TDCI XS,
7th Jan 2019 7:58pm |
Well Diff went today .
I’ve been caught up with things on the farm and hadn’t had time to switch it out , plus I was a little apprehensive as not done it before ! There was a crunch or two and all drive went. So I slipped it into diff lock and crawled up to the workshop . Drained the oil and inspected the magnetic plug !!!! Here’s how it looked . Click image to enlarge |
4th Feb 2019 1:37pm |
Just starting to strip it down now !
4th Feb 2019 1:38pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6266 |
I think it's fair to say you're going to find a problem
4th Feb 2019 2:01pm |
Click image to enlarge Click image to enlarge Yup it’s cooked ! |
4th Feb 2019 2:20pm |
even with my limited mechanical knowledge I'd say that's less than ideal.
good luck with the rebuild. |
4th Feb 2019 2:22pm |
Is the diff gasket necessary? Mine just appears to have copious amounts of rtv sealant around it . Could do both but would rather hear from experience
4th Feb 2019 2:35pm |
