Home > Maintenance & Modifications > Coolant Top Up
andrewlandy
Austria 2016 Defender 110 Puma 2.2 USW Alpine White
Coolant Top Up
Hello,
Can I top up the coolant myself with an off the shelf brand? If yes any suggestions what brand is best?
Also does anyone kn ow the part number for the coolant resevoir screw cap.
2.2 Puma 2016.
A
Post #755895 3rd Feb 2019 12:55pm
Yes you can, you'd need the same spec as LR recommend.
I'd recommend pre-mixed for simple topping up as it saves a lot of hassle.
I use Motul Inugel Optimal, however mine is a 2.4 so the specs could well be different.
I am sure someone in here will be along shortly who can confirm as from your profile I am assuming yours is a 2.2.
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #755908 3rd Feb 2019 1:32pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I bought one of these caps last week for my 2.2 puma 2013 & it seems to have solved the problem I had with the original leaking a bit. (The one I received is yellow not black as shown in the photo.)
https://www.island-4x4.co.uk/expansion-hea...-5725.html
Post #755916 3rd Feb 2019 1:51pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
Make sure it OAT (generally orange) do not mix the different types of coolant.
Post #755941 3rd Feb 2019 4:34pm
Sulisuli
I have a 2015 HT 2.2 and use this
 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #755951 3rd Feb 2019 5:04pm
andrewlandy
Coolant Top Up
Thanks all. Helpful.
Post #755952 3rd Feb 2019 5:07pm
Following reports that suggest they're more robust that the standard one, I fitted an Iveco cap to my expansion tank, which incorporates a blow off pipe:
They're not cheap, though, and tracking one down that I could buy on line was a bit of a challenge but I eventually sourced it from a website called 'Vexi', which is an online store operated by Norfolk Truck & Van Ltd:
www.vexi.co.uk/parts/iveco/view/I99489567/plug Darren
Post #755999 3rd Feb 2019 7:09pm
landy andy
I ordered the cap in the post above via the link. Went for the cheaper postage offer stating 5-7 days. Only ordered yesterday and it’s sent and being delivered tomorrow. Very good service.
Thanks for the info.
Post #756156 4th Feb 2019 12:20pm
