![]() | Home > Maintenance & Modifications > Coolant Top Up |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20953 ![]() ![]() |
Yes you can, you'd need the same spec as LR recommend.
I'd recommend pre-mixed for simple topping up as it saves a lot of hassle. I use Motul Inugel Optimal, however mine is a 2.4 so the specs could well be different. I am sure someone in here will be along shortly who can confirm as from your profile I am assuming yours is a 2.2. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 344 ![]() ![]() ![]() |
I bought one of these caps last week for my 2.2 puma 2013 & it seems to have solved the problem I had with the original leaking a bit. (The one I received is yellow not black as shown in the photo.)
https://www.island-4x4.co.uk/expansion-hea...-5725.html |
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 243 ![]() ![]() ![]() |
Make sure it OAT (generally orange) do not mix the different types of coolant.
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
I have a 2015 HT 2.2 and use this
![]() Click image to enlarge 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
andrewlandy Member Since: 07 Feb 2016 Location: Graz Posts: 82 ![]() ![]() ![]() |
Thanks all. Helpful.
Following reports that suggest they're more robust that the standard one, I fitted an Iveco cap to my expansion tank, which incorporates a blow off pipe:
![]() Click image to enlarge They're not cheap, though, and tracking one down that I could buy on line was a bit of a challenge but I eventually sourced it from a website called 'Vexi', which is an online store operated by Norfolk Truck & Van Ltd: www.vexi.co.uk/parts/iveco/view/I99489567/plug Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5988 ![]() ![]() |
I ordered the cap in the post above via the link. Went for the cheaper postage offer stating 5-7 days. Only ordered yesterday and it’s sent and being delivered tomorrow. Very good service.
Thanks for the info. |
