![]() | Home > In Car Electronics > OEM Alpine Subwoofer Wiring |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
I can supply the mating male connector if you want to make your own harness. Paul.
1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Ihod Member Since: 07 Nov 2015 Location: Berkshire Posts: 165 ![]() ![]() ![]() |
PM sent.
Very many thanks. Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
Received today, Paul. Very many thanks for your help and for dealing so quickly. For those after connectors - highly recommended. Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2231 ![]() ![]() ![]() |
Out of interest why did you buy the identical unit from ebay/amazon etc...?
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947 ![]() ![]() |
Did you get this working? Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Half way there.....and haven’t had time to get back to it, yet....
Dash out, rca leads fitted to head unit and routed behind dash, under gearbox housing carpet to the cubby and remote power lead spliced I nto head unit loom and also routed through. I’ve fitted the sub to the cubby; very firmly fixed through to the supplied metal backplate inside the cubby box. It doesn’t really effect rear seat leg room. I’ve got a Blus Sea fuse box installed in the battery box so just need to route power through from that and pin-out the other side of the plug for the OEM socket. I’m happy that it’s all going to look standard. And the sub was cheap. But I can’t help think an alternative sub would have been better (and probably easier). Will let you know what it sounds like when it’s done. Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
You are nearly there!
I had it from factory in my last 110 and it does help. Current 110 doesn’t so I am going to add one but as you say the new slimline Alpine unit might be an easier option Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 607 ![]() ![]() ![]() |
Ive been banging on about my stereo woes for some time now.
Just trying to get the sub running now. Bought same sub as this (integrated amp etc). ‘Fender already pre wired for it. Plugged in sub to connector under cubby, bought harness to connect to head unit. Still not getting anything. What am I missing? Thanks! https://instagram.com/bentheoandrews |
I didn’t have the loom so have had to pull all the wires through and pin them out to match the socket on the sub.
If you have the harness and the Alpine head unit, it should just be a matter of switching the sub on through the menus on the head unit. The sub section is buried in the sound setup (along with balance, faded, etc.). Admittedly still haven’t found time to pull the power through to mine yet..... Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
Ah, right, thanks. Yeah, I'm still not getting anything (and sound to driver's side turns off when I switch sub off in settings....)
Just going to finally admit defeat - there's a guy down the road who does a lot of audio installs on Defenders. Just going to bite the bullet and get him to sort it. https://instagram.com/bentheoandrews |
Did you get this up any running? I can’t decide if I should buy a new Non LR SWE sub or wait for a factory sub to turn up. Andy
Just buy the Alpine one for a fraction of the cost and plug it in. Takes 20 mins
Which one? Andy
https://rover.ebay.com/rover/0/0/0?mpre=ht...1514756215
Couple wires to connect to any headunit, live earth and your done. |
