Home > In Car Electronics > OEM Alpine Subwoofer Wiring
Page 1 of 5 12345>
Ihod
United Kingdom 1998 Defender 90 300 Tdi ST Rioja Red
I’ve taken the plunge and bought a take-off Alpine SWE-1200 sub. It’s the LR model with integrated amp and a single connector (below):
I was hoping when I took out the cubby I would find the appropriate connector - some on the forum have been lucky - but there’s nothing there (and nothing under the cover).
So my question is, is there a loom/harness I can buy (I’ve searched the diagrams and nothing appears and no obvious part number)?
Or do I cut the connector off and pull the L, R and remote to the dash and the power through to the battery box? This would need to be fused?
I’m no auto electrician so has anyone done this or managed to source the harness?
Many thanks Ian
MY1998 300Tdi 90 Hard Top (Now Soft Top)
MY2015 110 XS SW - Sold
MY2008 110 County USW - Sold
MY1962 Series IIa Truck Cab - Sold
MY1994 300Tdi 90 Hard Top - Sold
MY2001 TD5 90 Truck Cab - Sold
Post #748661 2nd Jan 2019 11:51am
PaulMc
I can supply the mating male connector if you want to make your own harness. Paul.
Post #748664 2nd Jan 2019 11:56am
Ihod
PM sent.
Very many thanks. Ian
Post #748686 2nd Jan 2019 1:54pm
Ihod
Received today, Paul.
Very many thanks for your help and for dealing so quickly. For those after connectors - highly recommended. Ian
Post #748993 3rd Jan 2019 9:35pm
bankz5152
Out of interest why did you buy the identical unit from ebay/amazon etc...?
Post #749093 4th Jan 2019 9:11am
mcma1
Post #752539 20th Jan 2019 7:53am
Ihod
Half way there.....and haven’t had time to get back to it, yet....
Dash out, rca leads fitted to head unit and routed behind dash, under gearbox housing carpet to the cubby and remote power lead spliced I nto head unit loom and also routed through.
I’ve fitted the sub to the cubby; very firmly fixed through to the supplied metal backplate inside the cubby box. It doesn’t really effect rear seat leg room.
I’ve got a Blus Sea fuse box installed in the battery box so just need to route power through from that and pin-out the other side of the plug for the OEM socket.
I’m happy that it’s all going to look standard. And the sub was cheap. But I can’t help think an alternative sub would have been better (and probably easier). Will let you know what it sounds like when it’s done. Ian
Post #752542 20th Jan 2019 8:47am
mcma1
You are nearly there!
I had it from factory in my last 110 and it does help. Current 110 doesn’t so I am going to add one but as you say the new slimline Alpine unit might be an easier option Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #752543 20th Jan 2019 8:50am
Farmerben
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Ive been banging on about my stereo woes for some time now.
Just trying to get the sub running now. Bought same sub as this (integrated amp etc). ‘Fender already pre wired for it. Plugged in sub to connector under cubby, bought harness to connect to head unit. Still not getting anything.
What am I missing?
Thanks! https://instagram.com/bentheoandrews
Post #755335 31st Jan 2019 9:24pm
Ihod
I didn’t have the loom so have had to pull all the wires through and pin them out to match the socket on the sub.
If you have the harness and the Alpine head unit, it should just be a matter of switching the sub on through the menus on the head unit. The sub section is buried in the sound setup (along with balance, faded, etc.).
Admittedly still haven’t found time to pull the power through to mine yet..... Ian
Post #755399 1st Feb 2019 8:47am
Farmerben
Ah, right, thanks. Yeah, I'm still not getting anything (and sound to driver's side turns off when I switch sub off in settings....)
Just going to finally admit defeat - there's a guy down the road who does a lot of audio installs on Defenders. Just going to bite the bullet and get him to sort it. https://instagram.com/bentheoandrews
Post #755400 1st Feb 2019 9:02am
mcma1
Did you get this up any running? I can’t decide if I should buy a new Non LR SWE sub or wait for a factory sub to turn up. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #764787 22nd Mar 2019 9:59am
bankz5152
Just buy the Alpine one for a fraction of the cost and plug it in. Takes 20 mins
Post #764910 22nd Mar 2019 10:26pm
mcma1
Post #764916 22nd Mar 2019 10:54pm
bankz5152
https://rover.ebay.com/rover/0/0/0?mpre=ht...1514756215
Couple wires to connect to any headunit, live earth and your done.
Post #764921 22nd Mar 2019 11:18pm
Page 1 of 5 12345>
