Home > Td5 > Hazard light in binnacle TD5 2001
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
I've "upgraded" and moved some switches from the right hand side of the steering wheel namely the hazard, fog and rear heater to the centre where the rear wipe switch is. All went ok and is working.
However the binnacle hazard warning light does not flash when the hazards are on. The new Carling switch flashes fine. To be honest I don't know if the binnacle light (Mine are all factory LED lights) has ever worked. Should it come on when the ignition is first switched like a lot of the other lights do, engine light, diesel filter etc? Mine doesn't.
Thanks in advance Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #755163 31st Jan 2019 7:14am
Martin
Site Admin
Is the black with red wire from the warning light connected to anything?
This is the diagram of the early Td5 switch (same as Tdi):
https://www.defender2.net/forum/post751808.html#751808
Does the Carling switch have enough poles to connect this up?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #755181 31st Jan 2019 9:02am
rallysteve
The Carling switch does not have a suitable connection for the binnacle 'tell-tale' lamp. There is no requirement for it as the Carling light now flashes.
As Martin says, when you wired up the Carling switch you would have had a black/red wire left over which drives the binnacle tell-tale.
If you want it working still you will need a relay with pins 86 and 30 connected to the right and left indicators accordingly, pin 85 to ground and pin 87 to the telltale.
Post #755192 31st Jan 2019 9:44am
Martin
Site Admin
Ahhh a nice mechanical AND gate Laughing
If you do this you don't need a great big automotive relay, a tiny one will do - just make sure it has a 12V coil.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #755203 31st Jan 2019 10:40am
MC84
Thanks Guys for the info, I'll look into this at the weekend. So I'm guessing the hazard binnacle LED's would have lit before I did the rewire? Remember I have a factory fitted LED SMD unit. all the info I can find seems to related to filament bulbs. Probably won't make a difference though, just saying Wink Thanks again Thumbs Up Thumbs Up Thumbs Up Mike
Ford 100e 1959
Post #755318 31st Jan 2019 8:49pm
Martin
Site Admin
There’s no hazard warning lamp on the pre-Td5 panel, it’s built into the switch Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #755340 31st Jan 2019 9:34pm
PaulMc
The 1999 - 2001 TD5, has the old style flashing rocker switch by your knee, as well as the flashing triangle on the instrument warning lights panel. Paul.
Post #755349 31st Jan 2019 9:47pm
MC84
Paul, that's what I have. I just don't remember if the hazard symbol lit in the binnacle or not before my re-wire! It's fine on the new switch and it does have a spare terminal I'm going to look at. As I say I have the "new" style SMD led panel/binnacle. I'll investigate further as I would like it to light in the binnacle is possible. Mike
Ford 100e 1959
Post #755361 31st Jan 2019 10:29pm
PaulMc
On the old style hazard switch (pre-TD5), the Black/Red wire for the switch's flashing tell-tale light comes from one of the switch connector terminals, and loops back to a 4.8mm male terminal on the side of the switch for the tell-tale bulb (there's a corresponding earth terminal on the other side of the switch).
On the early TD5 (1999-2001) the hazard switch and its wiring is the same as the earlier vehicles, but there's an additional Black/Red wire from the switch connector terminal, which goes up the instrument warning lights for the flashing triangle symbol.
The Carling hazard switch (from MUD Stuff) doesn't have a dedicated output for the warning light, as it's integral to the switch.
You could do as suggested earlier, and use a relay to provide the feed to the instrument warning light.
Or, you could open-up the Carling switch and solder a wire to the switch's warning light contact. Paul.
Post #755366 31st Jan 2019 10:48pm
rallysteve
Unfortunately it isnt quite as simple as connecting into the Carling switch. The illumination on the carling switch is a single LED which does both the backlight and tell-tale using a resistor and diode.
Post #755378 31st Jan 2019 11:25pm
MC84
Hi, traced the black and red wire and used the mechanical AND gate! All good, all working! Thanks for the great info Guys Thumbs Up Thumbs Up Mike
Ford 100e 1959
Post #758898 15th Feb 2019 10:36pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Please post a photo if your switch relocation, its always interesting to see what others do. Thumbs Up
Here’s what I did.
 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #758998 16th Feb 2019 4:21pm
MC84
New switches and bits
This is where I moved the 3 switches. The rear demister, hazard and rear fog. I also took the time to add a few extras in place of the 2 cup holders. I need my tea so added a MUD tray around the gear levers! Last year I added 3mm chequer plate to the inside and a useful storage box.
 Mike
Ford 100e 1959
Post #761595 2nd Mar 2019 9:57pm
4RF RDS
Nice switch set up Thumbs Up 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #761599 2nd Mar 2019 10:11pm
MC84
Thanks Thumbs Up Thumbs Up Likewise, looking good! Mike
Ford 100e 1959
Post #761623 3rd Mar 2019 1:16am
