![]() | Home > Td5 > Hazard light in binnacle TD5 2001 |
MC84 Member Since: 23 May 2016 Location: Near Bristol Posts: 360 ![]() ![]() ![]() |
I've "upgraded" and moved some switches from the right hand side of the steering wheel namely the hazard, fog and rear heater to the centre where the rear wipe switch is. All went ok and is working.
However the binnacle hazard warning light does not flash when the hazards are on. The new Carling switch flashes fine. To be honest I don't know if the binnacle light (Mine are all factory LED lights) has ever worked. Should it come on when the ignition is first switched like a lot of the other lights do, engine light, diesel filter etc? Mine doesn't. Thanks in advance Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
Is the black with red wire from the warning light connected to anything?
This is the diagram of the early Td5 switch (same as Tdi): https://www.defender2.net/forum/post751808.html#751808 Does the Carling switch have enough poles to connect this up? ![]() ![]() |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
The Carling switch does not have a suitable connection for the binnacle 'tell-tale' lamp. There is no requirement for it as the Carling light now flashes.
As Martin says, when you wired up the Carling switch you would have had a black/red wire left over which drives the binnacle tell-tale. If you want it working still you will need a relay with pins 86 and 30 connected to the right and left indicators accordingly, pin 85 to ground and pin 87 to the telltale. Steve 02' 110 TD5 Double Cab Rebuild Thread |
Ahhh a nice mechanical AND gate
![]() If you do this you don't need a great big automotive relay, a tiny one will do - just make sure it has a 12V coil. ![]() ![]() |
Thanks Guys for the info, I'll look into this at the weekend. So I'm guessing the hazard binnacle LED's would have lit before I did the rewire? Remember I have a factory fitted LED SMD unit. all the info I can find seems to related to filament bulbs. Probably won't make a difference though, just saying
![]() ![]() ![]() ![]() Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
There’s no hazard warning lamp on the pre-Td5 panel, it’s built into the switch
Paul, that's what I have. I just don't remember if the hazard symbol lit in the binnacle or not before my re-wire! It's fine on the new switch and it does have a spare terminal I'm going to look at. As I say I have the "new" style SMD led panel/binnacle. I'll investigate further as I would like it to light in the binnacle is possible. Mike
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
On the old style hazard switch (pre-TD5), the Black/Red wire for the switch's flashing tell-tale light comes from one of the switch connector terminals, and loops back to a 4.8mm male terminal on the side of the switch for the tell-tale bulb (there's a corresponding earth terminal on the other side of the switch).
On the early TD5 (1999-2001) the hazard switch and its wiring is the same as the earlier vehicles, but there's an additional Black/Red wire from the switch connector terminal, which goes up the instrument warning lights for the flashing triangle symbol. The Carling hazard switch (from MUD Stuff) doesn't have a dedicated output for the warning light, as it's integral to the switch. You could do as suggested earlier, and use a relay to provide the feed to the instrument warning light. Or, you could open-up the Carling switch and solder a wire to the switch's warning light contact. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Unfortunately it isnt quite as simple as connecting into the Carling switch. The illumination on the carling switch is a single LED which does both the backlight and tell-tale using a resistor and diode.
Hi, traced the black and red wire and used the mechanical AND gate! All good, all working! Thanks for the great info Guys
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987 ![]() ![]() ![]() |
Please post a photo if your switch relocation, its always interesting to see what others do.
![]() Here’s what I did. ![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
This is where I moved the 3 switches. The rear demister, hazard and rear fog. I also took the time to add a few extras in place of the 2 cup holders. I need my tea so added a MUD tray around the gear levers! Last year I added 3mm chequer plate to the inside and a useful storage box.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
Nice switch set up
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Thanks
