Michaelkan Member Since: 19 Dec 2018 Location: Bath Posts: 149 ![]() ![]() ![]() |
Will run a chain lock through the wheel. Im afraid that’s the only security available for these wheels.
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808 ![]() ![]() ![]() |
Will this work?
https://www.4x4overlander.com/product/defe...protector/ 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
That looks good but I'd be concerned about added weight, mine is heavy enough as it is.
If you do run any lock though it like a cable type, make sure all areas of it in contact with the finished surface are protected with a soft neoprene or foam or similar or you could easily find the paint surface damaged. Most have a splatic finish but even then it's not really soft as such. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I’m thinking something like this. At home I have a U lock on my bike. Will try that to fit otherwise will get one of these.
https://rover.ebay.com/rover/0/0/0?mpre=ht...2779180621 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11083 ![]() ![]() |
Great that you are looking into it
Yeah, that's the type I have got on the shelf ready to fit sometime.
I'd fit something like this over the top: https://www.ebay.co.uk/itm/2x-Black-MTB-Bi...Swv7pbzYN- Obviously check internal dia but that sort of thing would protect the wheel surfaces from abrasion.[/url] ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 438 ![]() ![]() ![]() |
Fitted a new radio
![]() Quality metal front and dials - looks good and is in keeping with Landy - not too flash ![]() Click image to enlarge Excellent DAB reception - even with the original Aerial Very good BlueTooth for audio streaming Very quick phone pairing and quality sound for phone calls ![]() Click image to enlarge Also bought a pair of Mud A Pillar Trim - to allow more room for routing cables - and installed the external phone mike into the top ![]() Click image to enlarge Fitted the GPS under the plastic wing top cover - good satellite reception ![]() Click image to enlarge I know the screen is small for SatNav - but if you listen to the commands you don't need to watch the screen - I have a large dash mounted SatNav for when I need more detail or when using MemoryMaps I also know its expensive but I am not going to justify the purchase any more than I need to justify owning a Defender |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6041 ![]() ![]() ![]() |
Order arrived from JGS
![]() Replaced the viscous fan Started looking at the hard start from cold. (not been started since Friday after coming home from work & briefly started last night morning eve) Checked glow plugs all measured between 1.6kohms and 1.9kohms from the tip to a earth wire. Pulled on plug and tested - glowed red for a good 20-25mm from the tip. Will check the others tomorrow but suspect they are OK. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
looking good. ![]() what are the two flaps hiding (bottom right and left)? |
One is for an SD card and the other is a USB connection
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3361 ![]() ![]() ![]() |
Looking good boode.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6050 ![]() ![]() |
Have you ever changed the injector seals? |
I like that. What is it, and how much was it please. |
Probably only when the head gone done around 5+ years ago? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
