![]() | Home > Puma (Tdci) > 2.4 TDCI stuttering at 65mph |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Is it standard engine wise?
Any remaps/egr blanking etc? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Topvaruk Member Since: 25 Apr 2018 Location: bratislava Posts: 69 ![]() ![]() ![]() |
Hi Grafty
Yes all standard with full history. |
Well that rules out EGR blanking. It does sound VCV related. Does it hunt when first started from cold? 2002 90 Td5 Station Wagon
The rev hunting can be sporadic too, mines does a little then not at all sometimes. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
Have you checked the coolant level?
If it's a little low it can cause the cylinder head temperature sensor to cut in giving the symptoms of fuel starvation/hitting the rev limiter. I don't suppose that it will be so simple, but simple is a good place to start! ![]() |
Hello Shropshire
Thanks for the reply Yes, coolant is good. Also changed the VCV today for a genuine ford item not cheap! The guy on the parts desk said they normally change the pressure sensor at the same time - so that’s on order now. Also the pressure relief valve ... may as well do it all. Into the world of changing random parts now. Also Just ordered another replacement MAF .... genuine this time rather than OEM type - a genuine CHT sensor. Next will try the turbo actuator Of course changing one at a time to see when (being positive here) it clears!! In the back of my mind ..... can’t help thinking it’s like the speed limiter coming in .... but it did go all the way to 85mph in the past Then .... it will have to go an independent ..... |
Customsteve
My Revs are fine ... Pulls like a train .... just hits a wall at 65 mph and struggles to get past it regardless of gear in pedal input. |
On the keep it simple theme - could the wiring harness be chaffing around some speed/pressure related sensor, they are known to rub and this can cause very odd problems? Maybe giving a false reading to the speed limiter?
I expect you will anyway but it's always worth giving the connectors to sensors a squib of contact cleaner. Be lucky ![]() Last edited by shropshiredefender on 26th Jan 2019 7:52pm. Edited 1 time in total |
Thank again
Yes checked all that .... although it could still be the problem and I just can’t find it. I would expect duff readings that I could see on my nanocom .... but everhkng looks fine. Upto the point it plays up as 65moh .... all readings seem correct. Am wondering is it’s skmoly crap in the fuel tank and fuel lines and the pump just can’t pull the fuel in fast enough ..... it started off last year with just doing it occasionally. So found a complete set of fuel lines and a cooler on eBay that I can clean up and for next weekend. Suppose or should clean the fuel tank out as well. Then there is just the priming process ..... my let my local indie do it for me. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8318 ![]() ![]() ![]() |
If it was lack of fuel would it not do it at high engi e revs lower speed.
Is it always bang on 65mph? And it never goes over 65mph?0 Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thanks for the reply JST
Used to be fine all the way to the speed limiter around 85mph Noticed last year it had a few hiccups then it would pass. Now it won’t go beyond about 65, noticed this yesterday trying to pass another car on a dual carriageway ..... just refused, nearly got to 70 after about a mile of trying. Really massive stuttering like an old V8. Thought it could be the throttle pedal but the nanocom seems to show it working fine. The frustration is that through the gears and upto 65 it goes really well, smooth idle, turbo running up nicely. Can’t see anything obvious via the nanocom other than at 65 the fuel rail pressure is fluctuating by about 20MPA .... it’s liek someone is lifting my foot of the pedal. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17850 ![]() ![]() ![]() |
VCV
Thanks for the reply Blackwolf
VCV already changed today although I don’t have the pump learn facility on my nanocom so will have to wait till it goes to my indie. Devided opinion is that it will relearn over time anyway. Is it true? |
i didnt do a relearn when i changed my VCV, it cured the irratic idle Cheers
