![]() | Home > Puma (Tdci) > 2.4 TDCI stuttering at 65mph |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8461 ![]() ![]() ![]() |
air filter ok? Cheers
Topvaruk Member Since: 25 Apr 2018 Location: bratislava Posts: 97 ![]() ![]() ![]() |
Try to answer all replies in one go, No smoke .... new hoses, the idle was always fine it’s the high speed driving that’s the problem .... like something is holding it back
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Mine did exactly this andcheckedwater level was way low topped it up and been fine since 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Thanks PJ but already checked that.
According to nanocom engine temp is low 80s which was a surprise even when gunning it. Have ordered a replacement CHT sensor as it’s cheap ,... I understand this drives both the gauge and the info to the ECU. Could be giving duff readings. |
mine runs around 80 deg this times of year. 87 summer under normal driving Cheers
Big Harold Member Since: 09 Jul 2018 Location: nsw Posts: 71 ![]() ![]() ![]() |
Fit a genuine fuel filter.
Mark |
Hi mark
Has genuine fuel filter - at the last service at a LR main dealer |
did you resolve this? Cheers
Maxime Member Since: 02 Nov 2018 Location: Trier Posts: 10 ![]() ![]() ![]() |
I had similar issues at the same speed. It felt like a first speed limiter. I got rid of it after removing the snorkel
![]() Best Maxime |
Many thanks for the reply
Are spending a lot of money changing all the sensors etc .... found out that the ECU has been updated with RHD software rather than LHD, somehow this had introduced a speed limit function of 100kph. Rather than pay my local stealer again and wait 12 weeks for a diagnostics slot (yes 12 weeks) ..... to put it right just had a remap flashed onto it. Now goes like a rocket and has no limiter what so ever. Thanks all of you for your help. |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
I don't drive that quickly but I seem to recall rev's hunting at tick over was resolved with a new MAF sensor for me.
good luck. |
