Home > Puma (Tdci) > Leak from interior light
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
Can you point me where to look and what to do to find where water is getting in above the head cloth or fitting.
I park my 2009 Defender outside my house and have started to see drips from the area of the interior light near the windscreen.
I am a bit hesitant to dive in until I have asked you Guys.
Thanks
Post #753425 23rd Jan 2019 6:42pm
Shorty53
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Mine was leaking through the cross roof seam. Solved by running a bead of black sealant into the seam (black truck).
Post #753443 23rd Jan 2019 8:06pm
Crofter
I will have a look at that tomorrow thanks.
Post #753451 23rd Jan 2019 8:35pm
dorsetsmith
may be Condensation forming in between head lining and cold metal roof had same problem in pick up cab roof winter 2013 fix it by lining the under side metal roof with sound proofing sheets
Post #753466 23rd Jan 2019 9:24pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
if its condensation get a dehumidifier and keep it inside works on my hardtop
Post #753582 24th Jan 2019 12:27pm
donmacn
dorsetsmith wrote:
may be Condensation forming in be tween head lining and cold metal roof had same problem in pick up cab roof winter 2013 fix it by lining the under side metal roof with sound proofing sheets
I'll second the point about condensation.
I have some 20/25mm thermal insulation on all of my roof panels - except the ribs in between, where the roof lining plugs go into. This morning I happened to notice a decent amount of condensation on those ribs alone! I guess it won't happen once the roof lining's back in - but it could definitely generate a lot of water. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #753591 24th Jan 2019 12:49pm
Crofter
Thanks for the replies this gives me some areas to investigate. Thanks
Post #753680 24th Jan 2019 5:40pm
