![]() | Home > Puma (Tdci) > Leak from interior light |
Shorty53 Member Since: 17 May 2013 Location: Lancashire Posts: 135 ![]() ![]() ![]() |
Mine was leaking through the cross roof seam. Solved by running a bead of black sealant into the seam (black truck).
Crofter Member Since: 19 Feb 2015 Location: Peterhead Posts: 169 ![]() ![]() ![]() |
I will have a look at that tomorrow thanks.
may be Condensation forming in between head lining and cold metal roof had same problem in pick up cab roof winter 2013 fix it by lining the under side metal roof with sound proofing sheets
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
if its condensation get a dehumidifier and keep it inside works on my hardtop
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1889 ![]() ![]() |
I'll second the point about condensation. I have some 20/25mm thermal insulation on all of my roof panels - except the ribs in between, where the roof lining plugs go into. This morning I happened to notice a decent amount of condensation on those ribs alone! I guess it won't happen once the roof lining's back in - but it could definitely generate a lot of water. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Thanks for the replies this gives me some areas to investigate. Thanks
