Home > Wheels & Tyres > Renewing tyres |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 389 |
Fine to just change the fronts. Only the daft models like the Freeloader and the other plastic tripe with rubber band transmissions is that precious about tyre swaps. Permanent 4x4 vehicles usually wear the fronts out noticeably quicker. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
20th Jan 2019 8:05pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6264 |
have you considered going for a 'new' set of wheels / tyres and selling yours?
someone on here has a set, done 100 miles. I have a set also which are cheaper but they've done more miles - I suspect the new tyres might be the better option? could be cheaper overall? I'll see if I can find the link for you. https://www.defender2.net/forum/topic65074.html |
20th Jan 2019 8:22pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 905 |
Thanks for the responses and the link caterham but I have decided to save a bit longer and replace the four so they are all new. The conti cross contacts ats that where on the last Defenders are still available and fitted locally so will keep a standard look
Mike |
21st Jan 2019 5:07pm |
scotsstag Member Since: 17 Jun 2012 Location: D+G Posts: 534 |
Put your fronts on the back and you'll get a bit longer out of the set. 04' 90 Td5 CSW..
22nd Jan 2019 12:42am |
Thanks, yes I could I am hoping that I can replace in the next couple of months so not a huge issue to be honest, seeing as I do low mileage.
22nd Jan 2019 10:01am |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2495 |
I quite like the Continental Cross Contacts, I think they're a good all round AT tyre. I had BFG's on my 300Tdi and had a couple of bad experiences under braking in the wet on tarmac. Most of my off road driving is on wet grass and light mud towing a horse trailer and the CCC's definitely cope better than the BFG's. Defender 90XS SW
22nd Jan 2019 10:35am |
That's good to hear, I have only read positive comments on them so must be good. I don't do much off road, occasional green lane is about it so don't need an agressive tyre.
I was quite happy with the general trs but seem to be getting hard to come by, or expensive when you do. Contis seem the natural progression and understated to look at. |
22nd Jan 2019 10:42am |
